Best LT1 cam for mild headword
Old 12-28-2006, 10:31 PM
gradez28's Avatar
Default Best LT1 cam for mild headword
What is the best cam to go with to get most power with only mild head work?
Right now (well, before i tore the engine down), I had a cc305 with stock heads and It was surprisingly quick, but i want a little more!
Ive heard about a "joe o" cam that is supposably good, but where the hell do i get a "joe o" cam? and what are the specs? lol
Old 12-28-2006, 10:40 PM
95FbFormula's Avatar
joe o is a custom cam maker but i don't think he does it anymore. As for customs there are a few people that do them. cc306 is pretty good off the shelf so is the cc503. to get the most power you should go custom but it will cost you around 350+
Old 12-28-2006, 10:44 PM
gradez28's Avatar
the 503 isn't much of a step of from my 305, and from what ive read the 306 is based off of "old technology" which im assuming is was designed more for carbed motors, so its not as efficient for fuel injection (just what ive read... theres obviously a lot of fast cars running it though).... any other suggestions?
Old 12-28-2006, 10:46 PM
if you are will to spend the cash there is nothing better then a cutom will work the best for what you want search bret buaer, or futral
Old 12-29-2006, 01:42 AM
rasputin's Avatar
custom cams, its stupid not to if you can afford the 75$-125$ increase
Old 12-29-2006, 01:43 AM
Gun5's Avatar
comp cams does custom grinds for like $2xx when i called them last time just give them car specs and such.. sounds good to me?
Old 12-29-2006, 03:16 AM
hashtagBMW
Speed Density's Avatar
Guy,
If you think the 306 is old as in old for carbd motors, you need to read some more.
I would definatly do a custom grind. If you have the specs on what your heads flow it will help a tremendous amount.
Wish you luck!
Tony.
Old 12-29-2006, 06:24 AM
Dzman's Avatar
My buddy had Bullet do him a custom cam sounds like from the specs they did agood job compairin them to the other custom lt cams.It cost him like 330 and that was with the shipping.
