4.10 Gears on my Z28
Guest
Posts: n/a
I ran 4.10's in my 94 w/a T56 and loved them....swapped the tranny to a 700r4 and the 4.10's were a little too much gear for a DD. Switched to 3.42's and they were better for driver duties but were not enough for drag duties. I am now running 3.73's and 27" tires on the 94 and 3.73's and 26" tires on my 95 w/a 4L60E.
cliff notes
4.10's are good for a T56
3.73's for a drag oriented A4
3.42's for a spirited daily driver A4
cliff notes
Guest
Posts: n/a
3.73's w/4l60...275/40-17
----1 ---2 --3 ----4
500 3.2 6.1 9.9 14.1
1000 6.5 12.1 19.8 28.2
1500 9.7 18.2 29.6 42.3
2000 12.9 24.2 39.5 56.4
2500 16.1 30.3 49.4 70.5
3000 19.4 36.4 59.3 84.6
3500 22.6 42.4 69.1 98.8
4000 25.8 48.5 79.0 112.9
4500 29.0 54.5 88.9 127.0
5000 32.3 60.6 98.8 141.1
5500 35.5 66.6 108.6 155.2
6000 38.7 72.7 118.5 169.3
6200 40.0 75.1 122.5 174.9
3.42's
--1 ---2 ---3 ---- 4
500 3.5 6.6 10.8 15.4
1000 7.0 13.2 21.5 30.8
1500 10.6 19.8 32.3 46.2
2000 14.1 26.4 43.1 61.5
2500 17.6 33.0 53.9 76.9
3000 21.1 39.6 64.6 92.3
3500 24.6 46.3 75.4 107.7
4000 28.2 52.9 86.2 123.1
4500 31.7 59.5 96.9 138.5
5000 35.2 66.1 107.7 153.9
5500 38.7 72.7 118.5 169.3
6000 42.2 79.3 129.2 184.6
6200 43.6 81.9 133.6 190.8
not much difference but I liked the 3.42's better if I was going to drive it every day...for a drag setup or frequent racing go with the 3.73's...I have them in both of my F-bodies right now
3.42's
Guest
Posts: n/a
Originally Posted by Revelation Z28
im at 2100-2200rpm at 65 or 70mph... cant judge good.
gas>me
gas>me
5th in the T56 is .73 and 4th in the 4L60 is .7...so to give you a good feeling of how 4.10's would be in an auto ride around in a M6 in 5th gear
Yeah that is a crazy jump. My mind was blew away when I went from the 3.42 to 4.10s, that was the first time I've had a gear swap in any of my cars.
Yep I love the t56, at 75mph your barely turning over 2k.
It takes way less effort to accelerate, which is where you use most fuel, not while cruising, so if you could control your right foot, gas shouldn't be so bad, I haven't noticed a difference yet, can drive for about 4 1/2 hours before stopping for gas, burn about 12.5-13 gallons in 4 hours or a little more.
Originally Posted by Ray@Nitrous Outlet
A T56 and 4.10's is a perfect pairing because of the .5:1 6th gear
well with my 4.10s, if you paid me for gas to ride around in 5th on the freeway then i would lol. i use 6th on the freeway and still get
i still miss my 3.42s, so i can drive on the freeway and sit at 1500rpm. and my gears would last longer.
to everyone with no traction: same here, when turning and on the gas i powerslide no matter what. especially in rain. when/if there is any
but on a drag radial rolling into first gear and through a quarter mile, it is just about the greatest feeling my bolt LT1 has ever had.
ps when you have too much power, 3.73s are fine with a t56. my friend's 74 nova with a 383/t56 does just fine
My friends are impressed when i loose traction turning out of my driveway going like 5 mph. After traveling 2500 rpm on the highway in my automatic, i realized this is a low cruisin or strip car. So what do i do? change the gears? nah i bought another car to drive to work.
a 9" would be great. 2 center sections. 1 with 4.11 or 3.90 and 1 with 3.50
