Valve cover question
Old Jan 22, 2007 | 06:56 PM
METAL MANIAC's Avatar
Default Valve cover question
Ok to may this may be a stupid question, but where can I get some valve covers that are tall enough to clear roller rockers and have the alternator notch so I don't have to mess with the factory alternator setup and I did try to do a search on this before asking and could not find any info....Thanks in advance for any help.........MM
Old Jan 22, 2007 | 07:03 PM
Red97Z's Avatar
Canton Racing makes a nice fabricated aluminum set, but they're pricey, like $220 if I remember correctly.
Old Jan 22, 2007 | 07:06 PM
hyperzone's Avatar
what RR ratio? from what I've read on here, most 1.6's will clear stockers with a little modding/cutting of the "webbing" on the underside. Then again, the LT4 composite covers were made for the LT4s which had 1.6's so they are another option. I personally dont have any RR experiences yet.
in case your wanting part numbers :
LT4 valve cover, LH = 12552321
LT4 valve cover, RH = 12552322
LT4 valve cover gasket = 10108625
LT4 valve cover mounting nut = 10108675
LT4 valve cover mounting stud = 10108674
LT4 valve cover mounting stud grommet = 10108626
LT4 valve cover PCV grommet = 10240678
LT4 valve cover oil cap = 12555685
Old Jan 22, 2007 | 07:15 PM
I will be using 1.52 Ratio Comp Pro Magnum Roller Rockers. Bump for MORE HELP Please
MM
Old Jan 22, 2007 | 07:47 PM
Torkman15's Avatar
10 Second Moderator
If you get the narrow body rockers you can still run factory centerbolt valvecovers.
Old Jan 22, 2007 | 07:48 PM
mikes98z's Avatar
I have seen some on evil-bay that are reasonable...new raised aluminum covers with the front notch for the alt.
Old Jan 22, 2007 | 07:57 PM
dsmawd350's Avatar
cantons are $212
Old Jan 22, 2007 | 08:15 PM
hyperzone's Avatar
What gaskets do those cantons use?
Old Jan 22, 2007 | 08:16 PM
94Z28Joe's Avatar
I run the stock valve covers with the comp pro mag 1.6's rr
Old Jan 22, 2007 | 08:22 PM
dsmawd350's Avatar
im guessing stock but you could always call or email them
"These valve covers are a stock replacement for '93-'97 F-Bodies."
stock replacement means stock gaskets I'd think
Old Jan 22, 2007 | 08:48 PM
hyperzone's Avatar
^^^ very true. Although laziness got the best of me here and I was just curious. I have the LT4 composites and dont plan on switching, just thought it might be benificial to the thread incase someone wants to go with the cantons to know what gaskets to get as well. Then again, they could just ask canton when they order them bitches so... oh well....
Old Jan 22, 2007 | 10:56 PM
buffman's Avatar
Pro Mags (wide body RRs) will fit just fine under stock covers.
Old Jan 22, 2007 | 11:10 PM
buffman's Avatar
I mean 5 minutes a side tops with vice grips.
BEFORE:
AFTER:
Old Jan 23, 2007 | 04:54 AM
leadfoot4's Avatar
I've got a set of GMPP 1.5s under the stock covers without any modifications. However, it was my original intention to use a set of ARP "perma lock" adjusting nuts, and they're a little too tall to fit under the stock covers. Therefore, I'm in the process of notching one of the Proform cast aluminum covers.
Old Jan 23, 2007 | 06:36 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Thats exactly what I did, I bent the lip up and my valve covers fit better then I ever had hoped.
Old Jan 23, 2007 | 01:33 PM
Fire67's Avatar
Stockers clear my Comp alum. 1.6 RR's... The ebay polished ones rubbed the front and rear rocker tip. I got a set of polished ones that were not notched and they rubbed as well. But I liked them so I took out the grinder and went to shaving for more clearance. Now, as long as I make sure to push them toward the intake when tightening them down, they do not make contact.
Old Jan 23, 2007 | 01:39 PM
WhyHelloOfficer's Avatar
I'm running GMPP 1.6 LT4 Roller Rockers and I don't have any issues under the factory valve covers. I love the look of the cantons -- I'd love to get them powdercoated black.
Old Jan 23, 2007 | 04:05 PM
maybe2fast's Avatar
will Vette valve covers work? will they fit and clear the wheel wells?
Old Jan 23, 2007 | 04:11 PM
Ls1Bait's Avatar
Yes they do.
Old Jan 23, 2007 | 05:41 PM
maybe2fast's Avatar
any pics of vette VCs installed!
