LT's & bullets
Old Jan 29, 2007 | 01:06 PM
95Firehawk0158's Avatar
Default LT's & bullets
Does anyone have a sound clip for a setup similar to mine with Long tubes and bullets in the y pipe, no cats and 3in factory SLP catback? Or maybe even a hooker or magnaflow muffler? Mostly I want to know if it will be too loud, not for me but my neighbors.
Old Jan 29, 2007 | 02:25 PM
camarolvr69's Avatar
it will sound wicked man. i have Pacesetter LT's, ORY, and TSP Rumbler Catback on my 97' camaro. Best sound ever. You can ditch that SLP catback and go with like a loudmouth or something. it wont be too loud i promise.
Seriously though i have been running my setup since november and my neighbors haven't said a word to me.
Old Jan 29, 2007 | 02:31 PM
Do you think two bullets in the y-pipe (one for each header) will actually quiet it down enough to make them worthwhile?
Old Jan 29, 2007 | 06:38 PM
no two bullets wont fit. the only way to put a bullet in the system is in the i pipe-the pipe in between the y and the over the axle pipe. and yes one bullet is enough-makes it sound mean
if you were running open headers then you could do a merge collecter muffler on each side, but that is mainly for people who have to pass a decibel test at the track. as long as none of your neighbors complain, and you dont meet up with any ***** cops you will be fine on noise. just drive slow when you are around the cops
Old Jan 29, 2007 | 07:00 PM
94Z396's Avatar
On my 94 Z28 with the new engine Tick Performance Performance Shop outta Mt. Airy, NC installed Bulletts off the headers or True Duals. I have a sound clip on streetfire.net search 398 LT1 and you can hear it!
Old Jan 29, 2007 | 07:29 PM
hyperzone's Avatar
I have LT's and TSP X-pipe with two bullets. Its pretty loud. Just idling is not so bad but, any abrupt change in RPM is very loud. Start-up is loud. Driving at a constant speed is fine but when you hit it, its loud again.
Old Jan 30, 2007 | 11:27 AM
ats5424's Avatar
I have hooker long tubes with a y-Pipe setup no cat with a morosso spiral flow and a turn down. i can post a sound clip of that if you would like. they sound similar. My buddy has dynomax bullets on his ls1 but he has an x pipe set up with true duals. my exhaust ends right under my passenger door.
-95 Firebird formula. LT-1 6-speed. 13.20
Old Jan 30, 2007 | 11:31 AM
ZFan88's Avatar
I have the same setup with a dynomax bullet instead of the morosso, sounds greatt
Old Jan 30, 2007 | 11:35 AM
the_merv's Avatar
Veteran: Air Force
This is Pace Setter LT's, Y-pipe, and a Bullet, no Cat.
Old Jan 30, 2007 | 10:55 PM
LS1 Eddie's Avatar
Anyone have a bullet in place of the cat and a normal catback? What will this do to the sound of the car?
Old Jan 31, 2007 | 01:59 PM
i dont think you can physically fit a bullet where the cat goes....the shortest bullet out there is probably gonna be the dynomax-same as used in tsp rumbler catback...its about 14" long. next problem would be it hanging low.my bullet is like 3.5" in diameter i believe. if you could fit a bullet there though it would deepen the sound and cut down on rasp(if there is any). its probably also not a good idea to eliminate 1 cat and still have one on your car...throw the flow out of whack.
