Pics of my catch can setup for you guys wondering how to do it.
Heres a few pics of mine.
http://picsorban.com/upload/catch can 1.jpg
http://picsorban.com/upload/catch can 2.jpg
http://picsorban.com/upload/catch can 3.jpg
The purolater breather filter just has mesh inside it so it won't clog up it will just stop the oil fumes from entering the TB at WOT.
where did you get that catch can? im thinking of doing that on my car as well, but i want to run both pcv and breather lines into a T-junction, then into the vacuum line on the driverside of the intake. I have the deutch breather you got as well so its just a matter of getting off my *** to do it.
Its a NLP catch can, but thunder racing is selling them now too. If you run the breather line into a T into the catch can then there won't be any circulation going on with the air in the engine, it needs to pull fresh air from the throttle body into the valve cover.
How is that? I thought the TB draws air from the crankcase through the valve cover and into the intake stream. the pcv valve does the same but from under the intake manifold, and back to the air stream through the vacuum hose.
BTW correct me if im wrong because i really dont know what's going on with the pcv system in terms of schematics. I was under the impression that it goes that way.
Your intake is different than mine, you have the vacuum line in front of the TB. My car just had a line going from the valvecover to TB and a u-line from the pcv to vacuum line on the side of the intake. that might be why it seems it wont work.
Originally Posted by buffman
^^^ actually it flows both ways
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm trying to figure out how to use a catchcan on mine too.
The manifold is coated in oil inside and it's not helping performance any.
i like and want todo.. total cost and can i get that breather from the same place as the can?
What Part # on the purolator
and I cant find "NLP catch can" anywhere online anywhere
currently I got a PCV valve going to TB from cover and my PCV on intake BLOCKED off so id like to get this setup going
Next level performance is a sponsor here, but thunder racing also sells the catch can, http://www.thunderracing.com/catalog...&sid=776#P5920. The purolator part # is B23165, I just ordered it online at http://www.partsamerica.com/ProductD...tnumber=B23165 and picked it up in the store. I also cut the little bottom part off that blocks most of the airflow since the side openings are still in the gromet. I checked my catch can after the first 1000 miles and it already ~1/3 cup of oil in it.
or I can just go with one of those cool ones the ricers use.. cheap and still a catch can dont know what that inline thing they give u is though
![](http://images.channeladvisor.com/Sell/SSProfiles/20062436/Images/AS-OCT-CH.jpg)
Originally Posted by Taubr Unit
All i did was put a filter in there. Works fine for me and i have no oil comming out of it or anything else. Am i missing something here of why your running a catch can and running a bunch of hoses everywhere? Not tryin to be ignorant, just asking why......
![](http://i45.photobucket.com/albums/f67/ibwsjerry/IMG_3224.jpg)
hummmm..... explain a little more on the whole vaccum leak please. Im still new to the lt1, iv only had mine for a year now.
I know what your talking about the PVC, mine is still routed into the manifold with the hose. So do i still have a vaccum leak with the filter on the fresh air breather? I thought thats all it was. So am i in the clear now?
Originally Posted by Gun5
bit of blowby?? eh? well your @ 100k though.. $94 is a bit much u know where to get those inline clear ones??? my engine has 700 miles on it but id rather still have a catch can/filter
