x pipe importance
Old Feb 22, 2007 | 10:19 PM
  #41
slick1851's Avatar
Originally Posted by Out1aw
From what I understand though, the power gains between a ORY and LT setup compared to a true dual setup isn't incredibly signifigant until you make enough power to need that kind of an exhaust system...
Please vist the external mod section and there are tons of threads on that etc...
Old Feb 23, 2007 | 03:46 AM
  #42
revtime's Avatar
I run purple horny header mufflers "True Duals" no crossover.
I almost never have to remove my exhaust when working on the car, a crossover just gets in the way in my opinion.
I have plenty of power and see no need to run a PITA crossover.
My car is loud but not stupid loud and I have never had a problem with the cops. I have no problem listening to the stereo but I will be removing it for weight reduction this year.
If your looking for every last ounce of power then a crossover is for you.
Otherwise I would skip it and not have to deal with the hassles.
Just one opinion of course.
Old Feb 23, 2007 | 07:59 PM
  #43
camar0corey's Avatar
Right, but how much power is the cross over actually worth? No one seems to have had a opinion on it. Chances are good I'm going to flange it, so I could drop the H pipe/muffler assembly or something, or well I guess probably have it up at the headers.
Old Feb 23, 2007 | 10:27 PM
  #44
12345678910's Avatar
kinda off topic but anyone know if a summit or jegs universal x-pipe kit will line up with pacesetter long tubes thanks
Old Feb 23, 2007 | 11:00 PM
  #45
Lazlo's Avatar
A universal kit is just that, universal. It comes with several bends and lengths that you cut and weld to make it all line up.
What I'm wondering is would it really be necessary to tuck everything up above the floor pan like most cat-backs are. Obviously with a lowered car you would, but has anyone measured how much ground clearance there is with stock springs? My friend had a 2nd gen and we ran x-pipe, flowmaster 40s and tailpipes under the axle and he never had problems with it scraping.
Also what's the quietest mufflers you could stuff under there, seems like bullets or hornies would be too loud IMO.
Old Feb 26, 2007 | 10:51 AM
  #46
redneck01's Avatar
search a little more..you'll find that people CLAIM that crossovers will net a little higher hp on the top end from x-pipes, while an h builds mid range. i figured that since most dragsters run no junction, it was pointless...so i had my car dyno-tuned for the straight pipes. i also now run cutouts. edelbrock mufflers have a great sound very deep and loud wide open as the borla xr1's. spintech mufflers shouldnt lose power, although it depends on the particular setup on the car.
every car is differnet.
Old Feb 26, 2007 | 10:53 AM
  #47
redneck01's Avatar
quietest muffler would be flomaster (like 50 series)..or some flowtech mufflers. borla mufflers are a little quieter, but sound kinda weird IMO. edelbrock is niice..but i preffered the bullets.
Old Feb 26, 2007 | 01:03 PM
  #48
Taubr Unit's Avatar
Go into the external mod forum and theres a sticky about exhaust set-ups and a lot of pics!! And YES, people use that universal x-pipe and it works fine. thats what im gonna buy, or just dump off some bullets from the collector. Dunno yet.
Old Feb 26, 2007 | 06:44 PM
  #49
Hmm just about everyone that does duals gets rid of the cross brace, which I can't do as my torque arm is hanging off it. Once again I'm indecisive about what I want.
Old Feb 26, 2007 | 08:04 PM
  #50
Strokinit383's Avatar
Why dont you just do a single 4 inch instead?
Old Feb 27, 2007 | 05:17 AM
  #51
Thats a idea I suppose, would I just run 4" piping after the pacesetter ypipe then? I'm going to be going with pacesetter longtubes. Or does someone make a 4" y pipe?
I also checked the external mod forum, someone there did TD's with the spohn torque arm, I PM'ed them to see what they purchased to run them.
