Reaching 1000 mile break in
Old Mar 15, 2007 | 01:13 PM
LT1_King's Avatar
Default Reaching 1000 mile break in
i'm reaching the 1000 mile marker in my rebuilt 355. it's just a stock rebuilt one. i changed the oil at 500 miles(10W-30). what is the best oill to use a synthetic 5W-30 or just conventional 5W-30? or should i stick with the 10W30? need help.
Old Mar 15, 2007 | 02:03 PM
lt197formula's Avatar
On my stock rebuilt lt1 I was told to switch to synthetic at 10k but after talking to a different shop (Gforce they are a sponser ->) who has been doing most of my recent work, they said just stick with conventional. It's what they run in all of their much faster lt1's than mine so I figured it will be plenty fine for me. No leaks, no problems or anything so far with 11k on the engine, hopefully it stays like this.
It's up to your personal preference on using 5w30 or 10w30, depending on location some people run a thinner oil in the winter and thicker in the summer. I run 10w30 year around here in Texas and it's fine.
Old Mar 15, 2007 | 02:13 PM
LT1_King's Avatar
i live near amarillo. do you think i should run 10 or 5? what kind do you use?
Old Mar 15, 2007 | 02:27 PM
White 96LT1's Avatar
stay with conventional until 5K then switch over to synthetic if you want to and until then switch ever 1000 miles: until you get to 5K
Old Mar 15, 2007 | 04:15 PM
King - It gets pretty cold up there so I'd probably use 5 in the winter and 10 in the summer. All I've run so far on my engine is Castrol GTX and probably won't switch to synthetic.
Changing the oil every 1k up until 5k is unnecessary for a stock rebuilt engine, after changing it at 500 and 1000 just change it every 3k for the life of the engine.
Old Mar 15, 2007 | 08:47 PM
LT1_King's Avatar
thanx for all the help guys.
Old Mar 16, 2007 | 12:33 AM
Gun5's Avatar
hell im running 20-50 GTX at the 1,200 mark on my 355... did 10-30 the whole break in changed it 3 times
Old Mar 17, 2007 | 12:46 PM
Snyper's Avatar
10...
Old Mar 17, 2007 | 02:01 PM
Gun5's Avatar
20-50 in texas heat and 10-30 in the winter texas winter wtf
