Need help finding LT1 WS6 part!
Old Mar 19, 2007 | 08:59 PM
onefastbird95's Avatar
Default Need help finding LT1 WS6 part!
I need to pick up the hose that goes from the LT1 intake to the MAF sensor that connects to the WS6 ram air airbox.... I called GM and they want something upwards of 100.00 and SLP said something like 60.00. These prices are insane for this small hose, I know I have seen them on ebay for like 10.00 but I can't find any right now. Someone please help me!
Old Mar 19, 2007 | 09:25 PM
emerica4601's Avatar
From: king of prussia, pa (home) and williamsport, pa (school)
the hose? you mean the rubber cuppling? if thats what your talking about, lowes has them for under 10 bucks.
Old Mar 20, 2007 | 10:15 AM
I need the rubber hose that goes from the throttle body 4 1/2 inches down to 3 inch opening which is the size of the maf... do you know which part I am talking about now... I would have no prblem getting a universal 3" flex hose but this part is special in that it is the correct length and goes down in size from like 4 1/2 to 3 inches...
Old Mar 20, 2007 | 10:31 AM
Imnotfast's Avatar
your maf should be 3.5 inches and a furnco used for PVC works good. Find it at any plumbing store
Old Mar 20, 2007 | 10:32 AM
fergymoto's Avatar
Go to a hardware store and get a 3" Fernco sewer pipe connector.
Old Mar 20, 2007 | 11:17 AM
LiENUS's Avatar
Cutting up an old rubber boot works well too
Old Mar 21, 2007 | 01:04 AM
I measured the throttle body and maf today and on the hose I would need one side to be oval shaped 4.75" x 3" and the other end has to be 3.5"
Old Mar 21, 2007 | 01:24 AM
LiENUS's Avatar
Good thing rubber stretches.
Old Mar 21, 2007 | 02:36 AM
97WS6TAConv's Avatar
It will stretch. Boiling it helps greatly. A lot of the WS6 owners switched out to that very sewer pipe connector you are reluctant to purchase.
Old Mar 21, 2007 | 08:32 PM
since so many people speak of this fernco I should probably give it a try and see how it works for me if I can't find the stock hose baffle... thanks for the help guys!
Old Mar 21, 2007 | 09:22 PM
Rick Speed's Avatar
the sewer pipe 3"coupling works perfect when you oval it out it fits the t-body perfect
Old Mar 21, 2007 | 09:45 PM
Formula WS6's Avatar
I used a 4" to 3" rubber reducer from Home Depot. It took quite a bit of cutting and shaving to get it where I wanted it. Also, I have the stock connector and compared to the home depot one, the stocker is very restrictive.
Old Mar 22, 2007 | 07:10 AM
that setup looks pretty nice on there!
Old Apr 4, 2007 | 10:32 AM
DC96TA's Avatar
I put a ram air hood and box on my 96 ta the part # I used from gm is 25170358 It worked great. I reused my old clamps from my stock intake.The part was something like 16 dollars.Its flexible plastic.
Old Apr 4, 2007 | 10:52 AM
96lt1m6's Avatar
this is the boot i think you are looking for,i have one left.name a fair price and its yours(not tryin to make a house payment)a reasonable offer that will satisfy the both of us
Old Apr 4, 2007 | 11:02 AM
Fire67's Avatar
The oval inlet of the LT1 throttle body equals a 4" circle, not 4.75. The MAF needs a 3.5".
Just get a 4" to 3.5" reducer and your set. ATP turbo sells a nice rubber one I believe is called a "Hump Transition" which allows a reasonable amount of movement without over-stressing the coupler.
