Cooling Fans
For some reason they stopped working. The Relay's were good, the Fuses were good, everything was good, even the Sensor/Switch on front of the Water Pump. I fixed it by splicing the wire to the Fuse/Relay Box there to one side of the Fan Circuit, and then grounding the other side. They come on and run constantly when the Key is turned to the on position. I am putting in in-line Fuses and a switch, so then it will be good. As far as I am concerned, it fixed that problem. It was a little work, but it's done and easy to troubleshoot.
I used a black plastic switch for mine, it was a double throw double pole type, don't know for Merv's mod, but normally you have to wire up the high and low speed to the switch. I mounted the switch in the little panel that holds the cig lighter. I'd post a pic, but my shifter handle is in the way.
The wires I used are under the Fuse box there.. I spliced into the orange 12g wire going to the Fan Fuse, and used the 2 wires coming off of the Fans going to that box(did a little wire tracing). Then I grounded the 2 other wires on the fans that weren't used.
On the other side of that Orange wire is a Brown wire. That one is hot when the Fuse is in, so I spliced into that one with the Blue and Green wires which are connected to the Relays, and eventually go over to the plug that goes to the Computer. I made them Hot wires, and took the ones out on the Harness side of that Plug. I did this so I can have some extra power wires there for when I do my LSX Conversion. The Brown one there also goes over to the other side, so I have 3 extra hot wires there now that can come in handy.
My *** needs a second job..
Fan Switch
-bryan
Why couldn't I just find a powersourse, like the cig lighter, and just run juice from it to the fans, through a switch? Would there be any thing against doing that?
-bryan
You will need a double pole double throw switch. Yes if you wire it up like the shbox diagram above, your fans will still work like normal if you forget to turn them on yourself.
I did this and love it, I flip them on when I'm stuck at a red light or waiting in line at the track. My temp gauge rarely sees above 180 anymore.
I didn't install the LEDs, so I can't tell you about that, I just remember that when I flip the switch up I have it for high speed fans, and when I flip it down its for low speed.
LOL, words for the wise; before you waste hours trying to get your fans to turn on check your fuses!
That's all it was, soon as I replaced it the primary came right on.
I'm not entirely sure I've got their mess straightened out since I have only put about 50 miles on that car. That wiring diagram is great though so I might have to use it if I can't make it work the way I want it to.
, lol, yeah i'm the clown because I didn't check my fuses and that's all it was. I think I still want to get some type of manual switch hooked up, for when I decide to really drive it hard!
