Progress pics of big boy LT1....
Old Mar 23, 2007 | 02:59 PM
Ponyhntr's Avatar
Originally Posted by Ls1Bait
Looks good............
What are you using for your ignition? It would be hard to get a opti were you welded it up
Conventional distributor in the back.
Old Mar 23, 2007 | 03:01 PM
TwoFast4Lv's Avatar
Lookin' good!
Reminds me of last year
Old Mar 23, 2007 | 04:16 PM
MEAN LT1's Avatar
Wow , all these Solid Roller builds, I cant wait to start mine!
Old Mar 23, 2007 | 04:24 PM
stevemilz's Avatar
Very nice guys........
Old Mar 23, 2007 | 04:50 PM
IllusionalTA's Avatar
Old Mar 23, 2007 | 04:55 PM
Imnotfast's Avatar
Looks good...Funny looking valve pockets.
Old Mar 23, 2007 | 06:27 PM
Hot94Z28's Avatar
Freakin Sweet
Old Mar 23, 2007 | 06:34 PM
OutlawZ's Avatar
yeah conventional MSD Pro Billet dist with crab cap. And a 7" MSD Crank trigger in the front.....
my old SRP pistons had the same valve pockets like that... why do they look weird????
Old Mar 23, 2007 | 06:58 PM
Ponyhntr's Avatar
I'm not sure, because every valve relief I have ever seen looks like that...
Old Mar 23, 2007 | 07:11 PM
onephatZ28's Avatar
Bad *** pics
Old Mar 23, 2007 | 09:02 PM
Imnotfast's Avatar
Look almost for a non-23deg head.
Old Mar 23, 2007 | 10:42 PM
  #32
OutlawZ's Avatar
which pics mine or Pepe's???? Cuz his pistons look different than mine. mine are flattop with -5cc valve reliefs..... his might be more than -5cc......
Old Mar 23, 2007 | 11:32 PM
  #33
roadtrip120's Avatar
OutlawZ
what cc AFR head are you running??
Old Mar 23, 2007 | 11:44 PM
  #34
OutlawZ's Avatar
competition ported AFR 227's..... the bad boys..... well other than the no longer made 215 RR heads....
Old Mar 24, 2007 | 12:20 AM
  #35
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
looks good! enjoy!
Permatex copper RTV, it is so damn good, i would eat it if it was edible! it seals the world! ok its late and i need to go to bed! got work tomorrow!
Old Mar 24, 2007 | 12:28 AM
  #36
SiDeWaYZz28's Avatar
damm bro its good to see the motor finally getting wrapped up
Old Mar 24, 2007 | 01:14 AM
  #37
OutlawZ's Avatar
Thanks taner, hey i noticed the 9.27, dayum that's f-in flying.... still on the stick too... impressive as ****... I can't believe that thing is still 3500+ lbs. Do you plan on getting it like 200-300 lbs lighter to get that 8.99???? i gotta think there's gotta be at least 150 lbs you can remove no????
Yeah it's been a LONG time coming.... some of it was part selection and planning but most of it was financial. i don't have the kind of income where i can just write a check for 15 large and be done with it... so it is what it is i guess... plus while i was financing the motor build i was also hard at work prepping the car's other systems (electrical, fuel, engine mgmt, suspension, drivetrain, etc)..... The motor is about 1/2 of what the final product will be.... basically everything on the car is new other than the body and frame
Old Mar 24, 2007 | 03:15 AM
  #38
-PEPE-'s Avatar
Brett (PEPE) Hey Taner speaking of diets I've decided to go on a diet...no I mean me , not sure what else to lose on the car without making a strict drag machine...so pushups here we come
Outlaw, my original R&R rebuild engine price with little things like in tank Walboro, etc came out to $13k, BUT...then I decided I needed the T56 rebuilt by Joe @T56 Rebuilds, then I needed a McLeod TD, then a custom Driveshaft...the a built 12 bolt...the "and then" kept on and on...KMember, Upper/Lower Aarms, BMR Trakpak Tq Arm....yada yada yada...$18k when all said and done....as of today when I order the cage and Kirkey seats, harness and the cam swap from last week with suspension tuning & narrowed Ford 9" ...I'm about $25k... But she's been paid for, owe NO debt on this car, just save as I needed, pretty rewarding when we're all done and running our goals right! Well that's what I keep telling myself ...
Old Mar 24, 2007 | 06:00 AM
  #39
Ironxcross's Avatar
Old Mar 24, 2007 | 11:50 AM
  #40
TwoFast4Lv's Avatar
I am with Brett. I easily had over $6K into my short block. I have NO idea how much I have in the heads....Lets say $2,500. I put around $2,500 in the trans. Then all the legal stuff. Full cage, window net, five point harness x2, SFI Balancer, SFI Flax plate, SFI Trans and Flex plate shield, Drive shaft safety Loop, Wheel studs, Battery re-location and more I am sure.
Oh yeah then the suspenion parts. BMR Adjustable TQ Arm, Lower Control arms, PanHard bar, Sub frame connecters, Front K-member, lower control arms, QA1/Hals at four corners and again more I am missing.
The N2O system is all custom not sure how much there but Every bit of $2k
Then it rolled into a new truck to hual it and a trailer to put it on
All I can say is bring your check book and a heathly apetite for destrucion
