Progress pics of big boy LT1....
Old Mar 25, 2007 | 08:52 PM
  #61
SiDeWaYZz28's Avatar
Originally Posted by -PEPE-
Will keep the rods in mind and pass the word locally. These are AFR 210s, LME gutted the flimsy AFR valves & springs, 5-angle grind, custom porting, flowing 319. Those are Ferrera valves, Nextek springs, titanium keeps, etc etc.
Might be selling these end of the season for some upgraded heads flowing about 350-370.
How much would you be looking to get for those heads?
Old Mar 25, 2007 | 08:54 PM
  #62
-PEPE-'s Avatar
haven't even thought about it man, I don't even think I'll be able to use the shaft mount Jessels when I switch to the bigger heads, think they will be offset Jessells. Anyway I'll cross that bridge about selling once I get there.
Old Mar 25, 2007 | 08:57 PM
  #63
-PEPE-'s Avatar
Originally Posted by taner
Pepe,
would you kindly let me know what heads will flow 350 plus cfm, and that will bolt up and work just as our AFR 227's do right now!
i will take one set as well!!!
And on that note, I'll humbly just say "I've heard" you can get that with the 215rrs and or the 227s, you'd know better than me bro, is that a crock of kaka?
Old Mar 25, 2007 | 09:14 PM
  #64
Speed Density's Avatar
hashtagBMW
215s
Tony.
Old Mar 25, 2007 | 09:18 PM
  #65
Z8'S's Avatar
You can get 350-370 cfm with a 215 rr but it is VERY EXPENSIVE.I just did that.
Old Mar 25, 2007 | 09:23 PM
  #66
IllusionalTA's Avatar
Alternative to a 215rr.. Maybe a bit cheaper?
http://www.ronsportingservice.com/im...lpro-specs.htm
Old Mar 25, 2007 | 10:02 PM
  #67
TwoFast4Lv's Avatar
Hehehe.
You have not checked prices yet I take it
Old Mar 25, 2007 | 10:39 PM
  #68
OutlawZ's Avatar
if i'm gonna do all that i'll just go 18 degree heads...... i've already got offset jesels on my setup right now so if we have to we can hog out the intake runner sideways..... don't think we'll need it right now....
Old Mar 25, 2007 | 11:31 PM
  #69
TwoFast4Lv's Avatar
THAT is exactly where I am sitting
Old Mar 26, 2007 | 05:15 AM
  #70
Originally Posted by TwoFast4Lv
Hehehe.
actually i have.. it's 1800 for the cnc work.. and 1800 for the castings.. then you just have to fill it w/ parts.. 23 deg stuff is good for those that have a short block already and don't wanna get into changin' piston's and the like.. other wise.. starting from scratch.. 15* or 18* all the way..
Old Mar 26, 2007 | 09:29 PM
  #71
94Z396's Avatar
Very good set of heads, Mine are LE trick flows that have been ported! They Flow 300 cfm! But i havent got to run the car or even drive cause of block issues!
Old Mar 26, 2007 | 09:56 PM
  #72
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
if i would have known that i would have done it a few years ago! that is incredible! especially with a 23 deg. lt style head. if you are interested i would gladly swap you for a set of 227's and a hogan intake with accessories besides what are you going to do wit hthat much flow on a turbo motor
Illusional,
I hear ya, i called them last year and they had no interest in converting for reverse cooling. and besides i am sure i could have found someone to do it. but i really couldn't drop over 10 large on changing my entire top and and pistons, etc.....
Outlaw,
sorry for stealing the thread
Old Mar 28, 2007 | 02:05 AM
  #73
OutlawZ's Avatar
Outlaw,
HA! I never worry about you and Sikora talking about head flow in any of my threads.. I learn alot from you guys when discussing stuff so keep talkin...
Old Mar 28, 2007 | 12:19 PM
  #74
Greenfire's Avatar
Some how you'll eventually get tired of hearing and seeing videos how well everyone's LT1's are doing and want to get yours back up and running. You know you want to burn a few off at the strip!!!
Nice build Outlaw! Been a while since we have seen you, sounds like you are doing well. Look forward to seeing your beast in action.
Old Mar 29, 2007 | 01:39 PM
  #75
Dragframe's Avatar
Just get a set of the 32valve heads and boost the living **** out of it.... Sky is the limit =)
Old Mar 29, 2007 | 07:04 PM
  #76
-PEPE-'s Avatar
Been there done that bro, you'll get it going man just hang in there...GO BIG
Old Mar 29, 2007 | 07:38 PM
  #77
damm who did your port work??
Old Mar 29, 2007 | 07:52 PM
  #78
hashtagBMW
Im assuming Lllyod Elliot ported his heads. I only say this on the grounds that he states 'Mine are LE Trick Flows'.....
Tony.
Old Mar 29, 2007 | 08:04 PM
  #79
Mike96z's Avatar
Well I dont use studs, so I wont have the leaking problem. Nice engine.
Old Apr 27, 2007 | 09:28 PM
  #80
FASTFATBOY's Avatar
Niiiice! Why are the coolant pass through holes in the deck not round, never seen any like that.
David
