Noob with first LT-1 need direction...
My questions are this:
1. Is there anything I should replace, swap, change, upgrade or look for while I have the motor out?
2. What is a good place to send my harness and computer too to get reprogrammed and harness converted and hacked and how much am I looking at spending on this?
As for you PCM...there are several places for a mail-in tune...PCMforless...madz28.com. they can do anything you want. well i hope i have helped a little....have fun with your LT
This is false. The B4C package (police package) had a stronger/stiffer suspension, better brakes, a beefed up alternator, and no badges, and they were all automatics. Other than that, they were the same as all other Z28's.
As for things to check, the first guy to reply hit the nail on the head. Depending on how much money you want to spend, I would reccomend this as being a good time to swap the cam out, and change the heads to a nice aftermarket set, as well as have the intake ported. You also might as well check the rear main seal since it will be easily accesable, and the intake and oil pan gaskets.
Not looking to spend the money on swapping the heads as the weight saveings on an old truck like this are kinda pointless to me. I think maybe a port and polish job to go with the cam and a good mail in tune would probably bemney better spent. I figure with the cam and the tune it should put me around 350hp???
Also are their any good aftermarket Opti-Spark units that are better than the GM units, MSD, ACCEL, other?
Here are some in progress pics of the truck and the engine.
Could be a 9C1 Caprice..
What did the Engine come from bro?
I know I should have saved up for the MSD. but I had to get the car back on the road at that time..
