Help LT1 Tuners! 248/254@.050" too big for stock pcm?
I have a 96 impala with a custom comp 248/254@.050" duration and 112 lobe sep. 383CI 10:1 compression, Ported Trick Flow LT-1 Heads, hooker headers, Burnt Pcm By Fastchip, stock MAF(also tested Granatelli with worse results), 1.6 rockers, comp tie bar hyd. roller lifters, MSD opti, wires and coil. 255 in tank pump, 42lb injectors, new Fuel filter,
Car is Breaking up like a misfire from 4200 up. Timing is staying at 35 deg. at wot. New o2 sensors, checked everything I can think of, Everyone around here is saying that the camshaft is too large for the computer.
Any ideas!???
Any ideas!???
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
I would say the cam is too big to be right but should run better than it is and that you have other problem as well.
Why is the compression so low?
Did you fab up a timing pointer to go with the MSD opti so you can 100% verify timing.
Sounds to me like a case of throwing money at a car without research and getting typical results from such. I know some of you will think I am an *** for saying it but sometimes people just need a wakeup call.
I had a similar problem with the car breaking up really bad at 3000+ and up with a brand new opti. it turned out that a wiringharness ground came loose by the starter and the righthand O2 passenger side header. good luck man and tell me how it goes. That cam is not to big. You need to go see a tuner though. he can find your problem.
9-Second Club
Originally Posted by Travis01gt
It has the PCM Tuned by Ed at Fastchip. They had all of the info when they burnt it. They are saying that the cam is too large?
Btw, you don't have NEAR enough compression for that cam. Never run less than 11.5 with that much cam, it will just be a turd unless you spray it, which covers up a lot of poor combinations. It would still be even faster on the bottle with the correct parts. I wouldn't use less than 12-1/12.2-1 compression with that cam if it were mine.
Good luck, Ed
may be valve float..check spring install heights. after you're safe on that..check the wiring to the ignition, if they are too close or out of wack they may act up. just little things that may have 10% chance of being a problem..and have been issues on mine.
