PCM 4 Less tune on 94 Camaro Z28
I agree... you wont see any real difference. sending the pcm out is a gamble, the only real purpose of sending it out would be to get the top speed limiter off, gear change speedometer change and shift points. and if you have a hypertech then you already ahve that. most people have to get it done 2 or 3 times when they do engine upgrades. or you can get the expensive LT1 edit and take it to a dyno by far the better choice. I would say until you put a cam in its better to keep it the way it is.
A mail order tune is worth it. I hand tuned mine and learned at the same time, first time tuning any EFI vehicle, spent ~3 weeks on it with great results. The guy at pcm4less has been doing it a while now and I'm sure his results are much better than mine.
Originally Posted by pcgamer4life
264 rwhp? Isn't that sort of low for an LT1 with bolt-ons?
If you got full bolts ons, Longtube headers, a highflow cat and lower stat, I think it worth getting it mail order tuned.
I have heard 8-12hp gains with a PCMforless or Madtuner tune.
If you have mids, I wouldnt worry about it.
bryan is worth every penny. you will love his tunes and they are dead on! i gained only 5 rwhp from his mail order and his dyno tunes. he had my a/f ratio dead on with the heads/cam setup
