Hp est. plz
Old Apr 5, 2007 | 01:09 PM
mumu_624's Avatar
Default Hp est. plz
HOw much Should i be hitting if i have
bored .30 over to 355
LE2 Heads
Gm847 cam
Full Bolts with 58mm tb
Custom built M6 Tranny
Old Apr 5, 2007 | 01:35 PM
LTBANDIT's Avatar
i would guess 420-440 rwhp...(just a guess)
Old Apr 5, 2007 | 01:45 PM
siniSSter's Avatar
Many factors come into play, but you should go over 400hp easy.
Old Apr 5, 2007 | 01:47 PM
mumu_624's Avatar
to the wheels right
Old Apr 5, 2007 | 01:51 PM
siniSSter's Avatar
Yup, RWHP (Real Wheel Horsepower)
Old Apr 5, 2007 | 01:58 PM
Turbo_6's Avatar
In a 6spd 405-410rwhp with a spot on tune. around 20rwhp less with an auto.
Old Apr 5, 2007 | 02:32 PM
streetwarrior96's Avatar
390 to 420
mumu_624's Avatar
wow thats big differents
but its M6
Old Apr 5, 2007 | 02:46 PM
LT1's Avatar
LT1
im really sorry to hyjack your thread since im on the same topic i thought i would ask if this combo would work and what numbers would it give me if it does work.
stock bottom end M6 Z28
AFR 227cc LT4 heads
LT4 intake (ported)
cc306
mis. injector, ignition, fuel pressure regulator, 58mm tb, ect.
dyno tune
Old Apr 5, 2007 | 02:51 PM
LTBANDIT's Avatar
AFR 227cc LT4 heads
LT4 intake (ported)
cc306
dyno tune
uh, less...
Old Apr 5, 2007 | 02:54 PM
LT1's Avatar
LT1
so you gotta do bottom end to go with that head/cam combo?
Old Apr 5, 2007 | 03:12 PM
AFR 227cc LT4 heads
LT4 intake (ported)
cc306
dyno tune
that head and cam como is useless. Lots of head to little of cam. For that go with some 190's to 200 CC
Old Apr 5, 2007 | 04:02 PM
nycto's Avatar
That would be Rear Wheel Horsepower, opposed to FWD cars putting FWHP down.
Old Apr 5, 2007 | 04:27 PM
LT1's Avatar
LT1
would that cam range and the AFR be ok with stock bottom end, or would it choke up.
Old Apr 5, 2007 | 04:54 PM
look at my setup in the link below. with a smaller cam the the 306. Though you can make your stock heads better for less
Old Apr 5, 2007 | 05:25 PM
mumu_624's Avatar
Hey how would a GM847 work with Mildly ported heads??
Old Apr 5, 2007 | 05:28 PM
probably better off with the 306 GM is a bigger cam
Old Apr 5, 2007 | 05:32 PM
mumu_624's Avatar
HOw much Hp will i be running if i have 355 with cc306 with mild ported heads...and Full boltons...
will it be Big difference going from a hotcam to a cc306
Old Apr 5, 2007 | 05:35 PM
360 to 380 I'd say depending on supporting mods and tune M6
Old Apr 5, 2007 | 05:36 PM
mumu_624's Avatar
i remember there was a website that tells you all the cams sizes and compares them
do you know what that website it was?
