3200 stall too much?
What do you guys think, a port job or stall? Now I'm debating between the two. I see a port job being nice, because it will give me some nice top end. I mean, maybe a 2200 stall and a port job...I'll save half the money with the small stall and use to port the heads...Bad idea?
I just would just to have that up top pull, so I can hang with LS1's. That's what I want more than anything. I know I will dominate off the line with a stall, but I want to beat an LS1 from a roll. It seems like the best way to do that is by porting the heads a bit. Am I just being stupid, or on the right track here...We have f-bodys meets and there is a lot of highway driving.
Like you have already been told, ported heads on a stock engine is not a good idea. Any gains in the upper rpm's will be minimal because of the stock cam. You will also lose some low end power and response due to lower port velocity. The stock LT1 heads are actually pretty damn good. Some people have gone into the 11 second range with them. Anyone who thinks the LT1 heads are a weak point should go spend some time talking with someone who grew up stuck with the smog heads of the mid seventies and eighties. Those were some poor heads.
A 2200 stall is an equally bad idea. More than likely, you won't even be able to tell the difference from the stock stall. It would be a total waste of money.
You have been given some good advice in this thread, but seem to have a hard time accepting it. You need to do your research before making any decisions. There is a data base of track times and dyno numbers with listed mods, on this site. Go there and find some cars that attained performance similar to your goals and study their mod list. Gather as much info as possible and make an informed decision instead of going off of preconceived notions.
A buddy of mine works at a cylinder heads shop and told me today that porting my heads and getting 1.6rr's would be a good idea and i may pick up 20Rwhp...He said the rr's almost work as a cam, giving me more lift. Now, you guys said I would lose power. That's where the confusion is coming from. But, it seems like you guys know what your talking about. I think I'll just get a stall, 1.6rr's and a nice tranny cooler and call it a day.
and the converter is NOT going to break your tranny!! JESUS! Buy a shift kit, and a GOOD traany cooler to go along with it. Yes, it will build more heat that normal, but nothing that 4L60 can't hanlde.....or 700r4, or what-the-****-ever is in that car.
Thanks for setting things straight. Using the fat girl analogy was hilarious. If it's that pointless, I better just get the ******* stall.
Lot of people here with mediocre cars trying to get everyone else to follow them down the same path of too much money for too little results.
On the tranny cooler look into TruCool or B&M with the viscosity based "thermostatic" feature, transmissions most definetely can run too cool and these coolers will help avoid that.
If you want to edge out a STOCK LS1, then just add a LT4 Hotcam kit and the 2800 stall. Be aware though, once the LS1 adds a cam and headers, you'll be watching his tail lights again. Those motors are so stinking responsive. After that, it's just a race of the wallets. Any motor can be modified to beat another but nothing is static. Once you beat the other guy, out comes his wallet and he's ahead of you again. When you get tired of getting beat, out comes your wallet until you beat him again. Repeat until you have a car that is either completely uncivilized or you (or the car) is perpetually broke.
But I wonder at what point the gas mileage of each becomes the same. With an LT4 cam in an LT1 I want to say it will get about 22mpg. The Ls1 with a cam (and a pretty big one at that) and headers with true duels and no tuning gets about 22-23mpg. I drove the car too and I want to say it is scary how fast it really is!! Makes anything I have ever driven seem really slow! And even with it untuned the car is dumping raw fuel right through the motor too! I have smelled it! I am willing to bet it will be over 400HP once its tuned. But back to the point I was trying to make is I think the LS1 will always beat the LT1 on MPG per HP, I think It helps a lot when you have a 6-speed too!
A 3200 stall would probably be plenty sufficient at getting what you are looking for. I will probably get rid of my 2400 and get a 3200. check out:
http://www.fuddleracing.com/default.asp --> I hear they are just as good as VIG. but easier on the wallet.
this mechanic...same one who told you you had a 900 stall???? i would stay as far away from him as possible. where are you located, maybe we can refer you to a reputable f-body shop near you, so that you can get correct info and put your money in the right places.
but for right now, i would go with a 2800 to 3200 stall....very tight, at least 2.5 STR, tranny cooler, and a REAL shift kit....trans-go preferrably!
bets of luck bud!
see what a few drinks can do to ya....its true, alcohol makes you speak the truth. all of what I said, even tho mis-spelled for the most part, was complete and brutal honesty.Like I said earlier, I think you should steer clear of this mechanic you have right now, unless you really trust his knowledge and ability with the LT1 motors.
Yep, unless you knew what a stall drove like, you couldn't tell it was there.
