Check this out...........
Old Apr 9, 2007 | 02:18 PM
LT1Z's Avatar
Default Check this out...........
Anyone ever had this happen or know where I can find good replacement parts? If you cant tell, the line running from the top of my pass side manifold(circled) is cracked and as a result, my fill neck has three holes burnt in it, causing my car to leak a good bit of oil all over the place. The line that runs into the side of the throttle body is cracked and has oil all over it as well and I drew an arrow to it.
Attached Thumbnails Check this out...........-100_0669.jpg   Check this out...........-100_0670.jpg   Check this out...........-100_0671.jpg   Check this out...........-100_0672_0001.jpg
Old Apr 9, 2007 | 03:02 PM
DC96TA's Avatar
I just had to replace my filler neck also leaking .
Go to your local gm dealer you can pick up all those parts for about $30.00
Old Apr 9, 2007 | 06:34 PM
Captainofiron's Avatar
thats just the crankcase ventilation hose, I just taped mine up when it cracked slightly
Old Apr 9, 2007 | 06:41 PM
dhdenney's Avatar
Did you know that the threads of the cap and the base of the neck are the same? If you wanted to, you could just remove the neck and put the cap directly into the valve cover.
Old Apr 9, 2007 | 06:56 PM
Formula413's Avatar
I'm a little lost here...are you saying oil spraying out of the line from the valve cover to the throttle body caused all that damage? That is just a breather line. Some oil does get into it but it shouldn't be spraying **** everywhere. You should probably do the breather mod that someone came up with. Where that line leaves the valve cover there is a little plastic elbow stuck into a rubber grommmet that the hose connects to. Replace that elbow with a breather filter. Autozone carries a Duetsch BF412 that will fit right into that grommet and connect to the hose. It helps keep oil out of the hose. Here's what it looks like:
The hose in that last pic (circled in purple) is for the bank 2 air injection system. If enough air is leaking out of that crack it will set code P1416. So if your ses light comes on and you get that code you know why.
Old Apr 9, 2007 | 06:59 PM
the_merv's Avatar
Veteran: Air Force
Remove the A.I.R. stuff, and just screw the Cap into the Valve Cover..
Old Apr 9, 2007 | 07:02 PM
LT14MULAWS-6's Avatar
im not sure what AIR has much to do with it but he is correct in the fact that the cap will screw right into the valve cover......thats how 93s came from the factory, atleast any that i have seen.......
Old Apr 9, 2007 | 07:06 PM
the_merv's Avatar
Veteran: Air Force
The little hose is cracked in his pic off of the A.I.R. Check Valve on that Manifold. Remove all that crap, it will run much better.
Old Apr 10, 2007 | 01:25 AM
LT1Z/28's Avatar
yup, that junk is just in the way anyways and it will run better
Old Apr 10, 2007 | 04:28 PM
LT1Z's Avatar
Thanks for all the replies. I never would have thought that the oil cap would screw right into the valve cover. I do have to pass emissions where I live though, and isnt it illegal to remove any emissions equipment?
Old Apr 10, 2007 | 04:51 PM
ABA383's Avatar
I know that here we have a visual emissions inspection and everything has to be in place...Technically you can not remove or tamper with any piece of emissions equipment...I run all of my AIR stuff and EGR and I use that Duetsch BF412 on my set up and its made a world of difference...Go to the dealer and buy the stuff thats bad and replace it...Its not too much $$$...I used to run the oil fill cap right into the cover, but my OVC wires got in the way, so I got a new filler neck from the dealer....either way works fine...
I think its way cool to run low 11s, pop the hood and still have a factory looking motor with the emissions stuff...I don't think I'd run faster w/o it hooked up...
--Alan
Old Apr 10, 2007 | 05:05 PM
Formula350's Avatar
I don't want to hijack, but do 93's come w/o AIR crap?
Old Apr 11, 2007 | 10:54 AM
PunkerPontiac's Avatar
93's also have the air system
Old Apr 11, 2007 | 11:35 PM
Formula350's Avatar
Alright. I honestly haven't looked, and mine didn't look to have enough plumbing for AIR.
Old Apr 11, 2007 | 11:58 PM
bigbadbowtie94's Avatar
shoot most of this stuff is easily found at the junkyard cheap. Just look for those good ole' chevy trucks.
