intake elbow question
Old Apr 9, 2007 | 07:07 PM
Lt14mla's Avatar
Default intake elbow question
Hey,
I just installed a csr electric waterpump and now i had to disconnect the long black tube that comes out the bottom of the elbow. Do i need this? what about the open hole now? suggestions...
Old Apr 9, 2007 | 07:12 PM
Phantomhp's Avatar
It isn't a must have type part. I believe most people remove them as I plan on doing.
You can use a pert plug bottle top and other home things to plug it.
Or you can go this route:
http://www.thunderracing.com/catalog...&sid=318#P1608
Mike
Old Apr 9, 2007 | 07:13 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Or you can get a 1LE intake elbow, I'd make sure I'd have a leak proof seal.
Old Apr 9, 2007 | 10:56 PM
Formula350's Avatar
It's called the "Donkey Dong" It's just a silencer. It's not important at all.
I used the bottom of a V05 shampoo bottle and a hose clamp. I have Speed Density, so a small air leak isn't any big deal to me, but if you run MAF, then as said you'll want an air tight seal. There's so many things you could do though. Carve a piece of wood to fit in there, silicone around some other item with a hose clamp, industrial staple the bottom of a V05 bottle + silicone. Just get imaginative You could always go over it to, instead of inside.
Old Apr 10, 2007 | 07:15 AM
LT1Falcon's Avatar
yea its useless. when i was building my falcon, i planned on having to buy a new elbow and then pluging the hole off with a wood plug, but when i was looking for prices on them, i found a new regular z28 elbow was about 150$ and a "1LE" elbow was only 50. i did some research on a 1LE , since i had never heard of a 1LE camaro, and found that the only difference was that the 1LE elbow didnt have that hole in the botttom. so it was a no brainer there, save a hundred bucks and eliminate the hole. i had to cut the excess rubber off of it tho, no biggie
Old Apr 10, 2007 | 07:49 AM
LT14MULAWS-6's Avatar
[IMG]I used the bottom of a V05 shampoo bottle and a hose clamp. I have Speed Density, so a small air leak isn't any big deal to me, but if you run MAF, then as said you'll want an air tight seal. There's so many things you could do though. Carve a piece of wood to fit in there, silicone around some other item with a hose clamp, industrial staple the bottom of a V05 bottle + silicone. Just get imaginative You could always go over it to, instead of inside.[/IMG]
or he could just get a new one.....................trickflow makes a pretty sweet looking peice for about a hundred, i dont think it has a logo on it so it would have that nice stock modified look...
Old Apr 10, 2007 | 07:50 AM
lol o ya prety close on our LS1 screen names lt14mla??
Old Apr 10, 2007 | 08:43 AM
LT1MAN's Avatar
i actually shoved a gas cap up in there and siliconed the **** out of it
Old Apr 10, 2007 | 09:03 AM
LT1Falcon's Avatar
isnt "stock" and "modified" an oxymoron? lol
Old Apr 10, 2007 | 05:16 PM
Formula350's Avatar
No, but it IS a contradiction
I got my Vortec alu one for like $70, but that was years ago. Don't know the price now. No name, no fancy look to it. Works nice. For my 93, the air temp sensor isn't compat. They screw in on the alu elbow and mine was push in to the factory. So I had to modify it to fit, since I couldn't find one that worked :\
Old Apr 10, 2007 | 05:31 PM
LT1Falcon's Avatar
lol yea thats it, not up on my grammar i guess. still doesnt make sense tho, stock and modified?
Old May 16, 2007 | 11:47 AM
Lt14mla's Avatar
so is the 1le elbow different size? am i gonna have to cut it?
Old May 16, 2007 | 12:13 PM
FAD2BLK93's Avatar
No...it just doesn't have the long dong on the end of it. BTW what hood is on that car thats f'n sweet. Is that the stock setup?
Old May 16, 2007 | 01:23 PM
Lt14mla's Avatar
THanks for the comment, but no its a us exotics warbird hood. and i absolutely love it lol, i believe you can still find them, but not sure if they make em anymore tho.
Old May 16, 2007 | 03:01 PM
LT1Z/28's Avatar
looks like a suncoast creations predator hood also.
Old May 16, 2007 | 04:54 PM
F8L LT1 Z28's Avatar
I would spend some money and just get the trick flow elbow and make it look good.
Old May 16, 2007 | 05:38 PM
That_guy's Avatar
dont you get more hp wit the 1le elbow or is that just a myth
Old May 16, 2007 | 05:46 PM
I don't know yet, BUT IT LOOKS bad *** and it works good with my N2O kit.
I have the trick flow elbow
Old May 16, 2007 | 07:22 PM
nychucky's Avatar
I peiced together this system for around 70 dollars including the k&N air filter and elbow and boy,...what a difference. You can hear it pull air and whistle at high rpm rates.
http://www.cardomain.com/ride/2195425/2
-Chuck
