Help.. i think some thing is way wrong...
Old Apr 18, 2007 | 08:40 PM
BsGreenZ's Avatar
Unhappy Help.. i think some thing is way wrong...
My car is bolt on car all mods are in sig.. i after i did my last tranny swap the car seems like it doesnt have the power it used to, so i thought it might have been my 02's since from what i know they haven't been changed since 94 lol so i changed them and noticed a little difference but on my scan master its retarding my timing by 7 degrees... i cant hear any valve tick or internal engine knock so i think every thing is ok so far but i still need to pull the passenger side valve cover to check my roller but i can hear any of them either.. what else would cause suck a retard on timing?.. and is it time to just pull the motor and rebuild it? help pls..
Old Apr 18, 2007 | 09:35 PM
96slow6's Avatar
How long has it been acting up? was it instantly bad after the swap?
Old Apr 18, 2007 | 09:39 PM
BsGreenZ's Avatar
before the swap it was kinda acting up but after is when i could really tell... it just feels way under powered and getting on my nerves bad...
Old Apr 18, 2007 | 09:49 PM
96slow6's Avatar
Hmm what have you checked so far, so i dont repeat what you have tried. Before anything else unplug your maf and see what it does. There is a reason i have people do this. I will explain if i need to but trust me.
Old Apr 18, 2007 | 10:53 PM
BsGreenZ's Avatar
i hope its not my maff, its a GMS... but the head gaskets are fine, the rollers are still adjusted right and not making any noise, no internal noise from valves or any thing, the fuel pressure is still up were it should be.... i pulled plugs and they all look fine, the wires are ok, no vacume leaks, no exhaust leaks.... i was thinking about a compression check but i dont want the bad news but im prepared for it...
Old Apr 18, 2007 | 10:57 PM
Dragframe's Avatar
yeah just run the car is SD and see how is runs...
Old Apr 18, 2007 | 11:08 PM
96slow6's Avatar
OK. The point of s/d helps narrow things down. S/d is more conservitive on fuel and timing and is less effected by other variables. Im sure your not but you didn't post weather or not you have and codes. But back to the point. GO for a drive with it in sd and post back any changes. If it doesnt get better then we will start on little things like filters. If it wont run at all then it points to map. If it does get better then we will go after cleaning the maf, air leaks in the intake.
Old Apr 18, 2007 | 11:18 PM
BsGreenZ's Avatar
the check engine soon light is not on and the scanmaster isnt picking up any codes
Old Apr 19, 2007 | 03:03 PM
Dragframe's Avatar
could be knock sensor.. or MAF (and honestly man... the stock MAF is the best one to have)... already change 02's... uhhh
Old Apr 19, 2007 | 04:09 PM
BsGreenZ's Avatar
i have the lt4 knock moduel and the GMS mass air but the car was getting on my nervse today so i took it to a back road and power braked it and let her go, she doesnt feel as fast as she did but kept the tires up in white smoke till the start of overdrive, but still retarded the timing 5 degrees....
Old Apr 19, 2007 | 05:26 PM
96slow6's Avatar
You are getting knock for some reason. Have you gased up recently and maybe got some bad gas?
Old Apr 19, 2007 | 05:31 PM
BsGreenZ's Avatar
i dont think thats it, it has done this for about the last month and i have to put gas in it at least 2 times a weeks... it felt strong today but not like it used to... what else could cause it, i was told that the long tubes might be causeing it for some reason.. im going to pull the valve covers again before tomorrow night...
Old Apr 19, 2007 | 05:39 PM
96slow6's Avatar
Headers can give false knock but its not likely. The lt's might be making it run pig rich. That would account for the slugish feel but not the knock count.
Old Apr 19, 2007 | 05:45 PM
BsGreenZ's Avatar
but the headers have been on it for about the last 7 months and its never felt like this.... im kinda hoping i just over looked a roller and its that... it still has ggod power but i miss holding it side ways from stop to the end of 4th but it could also be that since its warmed up the tires are just starting to hook a little better and im used to the power but how much power im a loosing with it retarding the timing from 5 to 7 degrees?
Old Apr 19, 2007 | 08:18 PM
96slow6's Avatar
I dont know. Anyone that posts a # is just guessing. If it down on power its down on power. Only you can tell. You never awnsered if you tried it with out the maf. Or if you tried cleaning it. Every sensor accounts for something. You have to awnser the questions or i cant help you anymore.
Old Apr 19, 2007 | 09:46 PM
BsGreenZ's Avatar
**** i for got about that, i'll go do that and let you know... opps i was so pissed this after non when i drove it i didnt pull the hood off and disconect it, i just stepped on the gas lol.. i'll let you know how that goes....
Old Apr 19, 2007 | 11:48 PM
96slow6's Avatar
Cool hope fully this will help us make some forward progress.
Old Apr 21, 2007 | 11:08 AM
BsGreenZ's Avatar
ok so i diconnected the maf and it ran like complete **** wanting to die so i hooked it back up and started to listen to the motor a little more and noticed a tick coming from the passenger side!!! damn roller had backed off just a tiny bit..lol.. thanks for all the help but know i need to order another new muffler lol i kinda grinded through it last night on my true dual set up lol... but thanks again guys for all the help...
Old Apr 21, 2007 | 11:57 AM
96slow6's Avatar
Replace your map sensor. If it runs worse with out the maf hooked up then your map is about shot. Ya and fixing the rocker might help it to. lol.
Old Apr 21, 2007 | 12:40 PM
The LT1 That Could's Avatar
i just wanna know what kind of piece of **** tires you have to be smoking them all the way to overdrive, lol.
g/l with the LT1 gremlins
