Fuel line mod write up (stock lines)
the loop is not hardly any tighter than the way they bend around on the top side factory.
daniel
Could you list all of the delete mods you've done under the hood?
I'm glad I found this thread. Just today, I called a shop to buy braided lines for the fuel line relocation. Fortunately, I didn't have measurements so I did more searches and came up with this thread saying that you COULD use the stock lines.
Do you get heavy fuel smells as a result of deleting your EVAP line? Does it effect emissions tests?
Thanks
. ABS deleted
Evap deleted
Air condition deleted
air pump deleted
over flow and washer bottle deleted
Basically just the coil, opti, injectors, water pump, tps and Map sensor is the only wires running anything on this car, spent alot of time cleaning it up under the hood.
Opted to just sell the Super charger after the cam broke on me, it was fun on the car, but also alot of headaches running 8lbs on a 12.8:1 engine
. The TNT kit cluttered under the hood more than I wanted so I let it go also. Next project when this engine goes, if it ever does will be a turbo set up, but I will have to start from scratch. Which sux, I have a great set of heads, but @ 48cc they are just too closed for boost.
But thanks for the props on the car guys.
