Fuel line mod write up (stock lines)
Old Feb 25, 2008 | 08:33 PM
  #41
94blownz281's Avatar
can you show me a picture of it and where you located it how it looks. where did you find this? i'm also thinking of mounting my power steering box on the frame rail so its hidden more. i forget did you also hide your computer?
Old Feb 25, 2008 | 08:44 PM
  #42
LALT1's Avatar
Computer is inside the car where the HVAC box used to be.
This is a overflow like I used. http://store.summitracing.com/partde...5&autoview=sku
Mine is completely hidden, it is basically right under where the ugly stock black on would be, this one is smaller lighter and cleaned up more on that corner.
Of course I fabbed up my own power steering and I am using a type II saginaw pump with res. mounted to it.
Power steering
PCM moved
And just for kicks how she looked about 18 month's ago
Old Feb 25, 2008 | 09:47 PM
  #43
97badass's Avatar
what cai is that? or is that a custom one?
Old Feb 25, 2008 | 09:50 PM
  #44
LALT1's Avatar
Custom, I ordered the couplers from intake hoses and the polished tubing was just a intercooler plumbing kit I bought and uses the pieces I could use.
Old Feb 25, 2008 | 09:54 PM
  #45
glocklimited9's Avatar
dammm your car looks and sounds awesome, what kind of valve covers are those??
Old Feb 25, 2008 | 09:57 PM
  #46
97badass's Avatar
well i like it a LOT, you should make a few and sell them, btw i love your enginebay, how do you go about deleting the evap?
Old Feb 25, 2008 | 10:01 PM
  #47
LALT1's Avatar
thanks man, here is a link to them.
http://cgi.ebay.com/ebaymotors/SBC-F...QQcmdZViewItem
Old Feb 25, 2008 | 10:19 PM
  #48
James Montigny's Avatar
Looks awesome, I just don't understand why GM ran them up front to begin with?
I figured they were trying to keep em away from the exhaust.
Old Feb 25, 2008 | 10:25 PM
  #49
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Well, I'm adding this onto the to do list of things for the car.
Old Feb 25, 2008 | 10:30 PM
  #50
Thanks. man relocating the computer had to be a pain with making all the wires longer..
Old Feb 25, 2008 | 10:32 PM
  #51
LALT1's Avatar
Didn't extend anything, plenty of wire there, just need to unloom it and retape and loom it how you need it to run.
Old Feb 25, 2008 | 10:35 PM
  #52
even when you hide the wires under the fender?
Old Feb 25, 2008 | 10:55 PM
  #53
zlover129's Avatar
looks great, as usual man, im looking forward to competing against you coming this next gathering or better yet come chill with us around our keg, i promise you, by looking at your engine bay, you'll fit right in That is if the gathering happens. You should come out to beach week too.
Old Feb 26, 2008 | 04:55 AM
  #54
LALT1's Avatar
I am going to try and come over to Beach week!!!
Old Feb 26, 2008 | 12:13 PM
  #55
LT1Formula007's Avatar
Love the engine bay man!
And Definentely gonna do this mod as well, Thanks for the write-up!
BTW If you could shed some light on the abs delete that would be awesome. I'm not using my abs and want to get rid of it and wondered what all I needed to do to get rid of it. Any help would be appreciated! Thanks
James
Old Feb 26, 2008 | 12:27 PM
  #56
All you do is remove the box, buy a brake valve and splice it into the brake lines. go to summit racing and look under brake parts.
Old Feb 26, 2008 | 01:05 PM
  #57
what about the proportioning valve?? Do I need another one of them or something since I'm bypassing the abs completely. I was under the asumption that the abs unit also regulated the pressure to the brakes (front to back)?
Old Feb 26, 2008 | 02:19 PM
  #58
I only have one and have talked to other people and they just use one as well. my car has been under the knife ever since i installed this so i can't answer the pressure question, but you should be fine.
  #59
sending you a PM as well
Old Feb 26, 2008 | 02:30 PM
  #60
Thanks for the info....
And to LALT1... Damn that enigne bay has came a long way in the past 18 months man, keep up the good work...
