LT1.. 2 or 4 bolt main?
Old May 5, 2007 | 09:35 PM
yamablaster024's Avatar
Default LT1.. 2 or 4 bolt main?
Couldnt find an answer...always wondered
Old May 5, 2007 | 09:44 PM
04gtoBMXracer's Avatar
4 bolt
Old May 5, 2007 | 09:47 PM
Skrilla's Avatar
F-Bodys 2 bolt
Vette 4 bolt
Old May 5, 2007 | 10:20 PM
ZONES89RS's Avatar
In-Zane Moderator
LS1=6Bolt...batards wouldnt need it if they werent all aluminum!
Old May 5, 2007 | 10:26 PM
procamaroz28's Avatar
d & b bodies are all 2 bolt
y bodies are all 4 bolt
f bodies are mixed most have 2 bolt but some have 4 bolt like the cop ones or 1le or a bunch more i think most of the dual cat f bodies are 4 bolt
any police lt1 is a 4 blt
Old May 5, 2007 | 10:30 PM
ZONES89RS's Avatar
In-Zane Moderator
Good to know!!! I thought it was only vettes.
Old May 6, 2007 | 10:05 AM
rkinney's Avatar
Alot of replacement engines, replaced under warranty, were 4 bolts. Mine was.
Old May 6, 2007 | 11:25 AM
Captainofiron's Avatar
my 97 came with a 4bolt originally from the factory
I have heard that some of the 97s got left over vette blocks that were in a warehouse somewhere
Old May 6, 2007 | 11:56 AM
StealthFormula's Avatar
I wonder if my '97 may have a 4 bolt main, how do you know?
Old May 6, 2007 | 01:07 PM
Gun5's Avatar
gotta pull the oil pan i imagine
Old May 6, 2007 | 01:16 PM
ZONES89RS's Avatar
In-Zane Moderator
Unless there is a casting number that might note this, and i doubt it...^ +1.
Old May 6, 2007 | 01:41 PM
yea gotta pull it to visually see, the casting numbers are the same
check it out
Old May 6, 2007 | 03:05 PM
OutlawZ's Avatar
1LE's are not 4 bolts from the factory... I have one and it's always been a 2 bolt (obviously not anymore)...
just wanted to clear that info up.... alot of leftover vette LT1's were used as GM replacement engines so that's how the 4 bolts ended up in F-bods.... if you got one you were lucky....
Old May 6, 2007 | 03:10 PM
Dragframe's Avatar
well my engine is a new shortblock as of last year... when i bought it. The dealership installed a new shortblock so i wonder what mine is....
i actully hope its a 2 bolt.... cuz i want to do splayed mains.
Old May 6, 2007 | 04:56 PM
really my bad i thought 1le were all 4 bolt
Old May 6, 2007 | 04:59 PM
Karl Ellwein's Avatar
Accept, every 9C1 cop car motor I have seen has been 2-bolt.
Karl
the_merv's Avatar
My LSX Block is Iron with them 6-Bolt Mains...that is goin to be 1 tuff mother..
Old May 6, 2007 | 05:02 PM
Stroker396@APF's Avatar
I have a cousin who worked on the production line for them and she couldn't tell me which were which.
I added splayed mains to mine.
2 things- 1 be careful which ones you buy. My machine shop had a big problem with the first set due to the cheap chinese metal.
Second, it was expensive.
after the holes were drilled I could not switch to the more expensive but quality american product due to the different angles 17* American made 18* Chinese. I ended up buy 2 more sets and the second set machined ok.
Old May 6, 2007 | 05:04 PM
dang merv, that is a beautiful sight
