Griffin or Be Cool?
Old 06-05-2007, 07:10 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Default Griffin or Be Cool?
I'm running hot during warmer days and the temp gauge just keeps going up with the AC on. I'm running the stock radiator. Summers coming and I wanna cruise! Time for an upgrade!
Griffin lists one specifically for the LT1 F body good up to 600 HP.
Be Cool says they have radiators up to 1,200 HP but the only ones they have listed for our cars are up to 400 HP and are listed as "1993-2002"
Which one should I get guys?
Old 06-05-2007, 07:34 AM
TwoFast4Lv's Avatar
I am running the BeCool with no problems.
BeCool rates theres for continuos use ar high RPM BTW. I have had mine out on 100+ Degree days running hard and Idlong with no problems
We have Yet anouther one in a 700RWHP Blower car with no problems as well
Old 06-05-2007, 10:57 AM
speed_demon24's Avatar
Running a becool in mine with no complaints as well. I had to move the radiator support back and drill new holes for it to fit since I kept the ac, other than that it was a direct boltin.
Old 06-05-2007, 11:15 AM
birdmaro's Avatar
i know this isn't an option but i have a Howe radiator/sbc fan in my 79 ta with an lt1. when im driving temperatures are right around 125-150 (150 on those 85+ sunny moments). when im in stop and go traffic temps are right around 200 (this is with a stock thermostat) but will kick down to 150 in about a minute of 25+ driving
Old 06-05-2007, 02:10 PM
streetwarrior96's Avatar
running into the same problems here.. as soon as the A/C goes on the temp goes up. with it off the temp is at 180/190. I have the 160* thermo, fans go on at 160, no air pockets and radiaor flushed and EWP. A/C has freeon full also. Does the griffin require mods cause I really don't want to cut anything
Old 06-05-2007, 02:22 PM
azvforce's Avatar
Are both these radiators for use with factory air conditioning?
Also, while on the subject, has anyone upgraded the factory fans?
Old 06-05-2007, 02:27 PM
Fire67's Avatar
Not sure about the Griffen, but with the BeCool... They revamped their design and no the only mods required are to the rubber saddles that it sits in. Due to the larger tanks, the saddles need to be simply cut down with a razoe knife. Mine fit with the A/C and everything no problems, and its maybe 6months old.
Highest temps Ive ever seen was 210* after a good thorough beating and then having to sit in traffic. Never went higher, and went back to normal 170-180* temps within a minute of driving.
Old 06-05-2007, 02:52 PM
^^^ good ... don't really need to change anything
Old 06-05-2007, 04:55 PM
Imnotfast's Avatar
Stay away from Griffen! They are glued together and after a while or high temps 250+ they start to fail.
BeCool, and most other aftermarket use Visteon cores are furnace brazed then weld there end tanks on.
Old 06-05-2007, 05:29 PM
Paul Bell's Avatar
OK guys, we've got a bunch of positives for Be Cool, one negative for Griffen. Now, I've had a Griffen in the Monty for about 20 years with the epoxied tanks and haven't had a single problem. Aside from having glued tanks (that sounds bad), is there anything wrong with using Griffen? Has anybody had any real problems with them? Has anybody here used Griffen in their cars?
Honestly, I'm leaning towards Griffen because it has the dual 1.25 cores (1 inch max on the Be Cool) and they rate it at 600HP vs. 400 for the Be Cool. I know, TwoFast4Lv runs a Be Cool w/ 700RWHP, surely the Griffen could cool at least as good if not better with wider cores.
Azvforce, you mentioned upgrading the factory fans. To what? I haven't seen or heard of this upgrade. Share what you know with us LT1 die hards.
Thanks for the info and experiences, guys, keep it coming.
Old 06-05-2007, 06:46 PM
Imnotfast's Avatar
Paul you make a good point. Yes the tubes are a little bigger on the griffin. Does it cool as well as say a Visteon or a Behr core. Will have to NO Way. Have tested just about every core out there and find the Behr and Visteon to have the best performance heat rejection for the core size. meaning the same surface area. Lot has to do with fin shape and per cm.
My personal rad is a Behr core.
Old 06-05-2007, 11:54 PM
TwoFast4Lv's Avatar
I talked to BeCool and gave them the mod info to get the Radiators to fit with A/C fine.
I run MY A/C in 100+ degree heat with an Electric Water Pump and a Cemented Block. Even after an all out N2O run it never gets above 200 Degree's.
Works good for me
Old 06-29-2007, 07:20 AM
MIGHTYMOUSE's Avatar
i was not able to find a 'direct fit' radiator on becool's website.. the 'module assembly'
somebody throw me a bone?
http://www.becool.com/#Search
Old 06-29-2007, 08:14 AM
-PEPE-'s Avatar
I used a Griffin universal and saved $200 bucks, saddles worked fine, AC worked fine (until I removed it).
Old 06-29-2007, 08:22 AM
TwoFast4Lv's Avatar
they are there THey only rate them at 400HP with factory fans. there mod kit is the same radiator with there fan kit
Standadard Trans 60246 and Auto($$$) 62246
Old 06-29-2007, 08:40 AM
ahh, so same radiator... they say their fans are better then stock?. well ok then
wait a second, if its the same radiator then my stock fans won't mount to it?
Old 06-29-2007, 09:54 AM
dhdenney's Avatar
May just be the same basic design and then the specific app have brackets and tabs for the car.
Old 06-29-2007, 09:55 AM
dhdenney's Avatar
Have you guys tried cleaning out your stock radiators? A little calcium or lime could kill the cooling capabilities.
Old 06-29-2007, 11:33 AM
lethal93ta's Avatar
I put an after market griffen in mine, I needed more room to work so I cut the rad support out and welded a 1x1 tube in there in it place, theres a lot of turbo guys doing this with out any problems with cooling
Quick Reply: Griffin or Be Cool?
