LT1 Coil Pack Conversion, modifications
Old Jun 8, 2007 | 05:01 PM
  #41
titter's Avatar
I am still more partial to the LTCC than the Delteq. Either way ... the setup is better than the opti, or a dynaspark. Price wise, the Delteq will win, LS1 coils are expensive for MSD aftermarket coils ... about 600 for all 8 in a set. Used you can find them for cheap. To each's own.
Old Jun 9, 2007 | 01:13 AM
  #42
96silverram's Avatar
another pair of shots showing the DELTEQ setup and the MSD DIS4
Old Jun 9, 2007 | 04:10 AM
  #43
titter's Avatar
Very clean setup ... must be nice to have a ram air hood, gave you a lot more mounting room.
Old Jun 10, 2007 | 07:53 AM
  #44
SmokedOutZ28's Avatar
In the last picture is that Dig 6 you have hooked up to the ignition system? Also what are the other two items on the other side of the bracket and do they come with the delteq kit?
Old Jun 10, 2007 | 01:19 PM
  #45
Formula350's Avatar
lol What else would it be hooked up to? MSD: Multiple Spark Discharge.
Old Jun 10, 2007 | 03:51 PM
  #46
LOL ha ha, Do you honestly think i don't know what MSD stands for? Since you obviously have nothing else better to do then quote my post and make some smart *** comment you could of not wasted my time and offered some assistants! And since you want to point out things you could of pointed out that the answer was posted by silverram when he posted the picture and that infact he is using a DIS 4 and not a DIG 6, that would of been helpful but since i had to come back here and read your post i found it myself! But i will give you credit since some of your ignorance has been useful in finding 1/2 of the answers i was looking for.
Silverram im still wondering what those other two items are. The reason why i ask is because i was going to go with the LTCC kit with LS2 coils but i couldn't use my dig 6 that i was using to control my nitrous retard functions so if i could use something along the lines of the dig 6 with the delteq ign setup that would be great and help out alot.
Old Jun 10, 2007 | 04:27 PM
  #47
titter's Avatar
Smoked the LTCC controller can retard timing.
Old Jun 10, 2007 | 05:45 PM
  #48
Formula350's Avatar
Well fine, you want productive? The MSD appears to be a 6Plus box, which I'm sure you know. Those 2 boxes, well 5seconds in google....
The Dual Ignition Adapter is designed for vehicles using MSD DIS Ignition Controls. It has two channels, for two coil pack applications. In some applications, when you add an MSD Ignition, the factory ECU no longer can tell when the coil has fired which is what tells the ECU to fire the injectors (or the tachometer). This Adapter simulates the coil signal thus allowing the ECU to properly trigger both the tach and fuel injection with the MSD DIS Ignition. In most cases, the Adapter plugs directly into the MSD's Harness.
Old Jun 10, 2007 | 09:11 PM
  #49
Really i didn't know that bob didn't mention it when i e-mailed him. Do you know if the retard function can be activated with the nitrous like the msd or is it always retarding timing? i would check on the site to make sure i didn't overlook anything but i cant seem to find it at this time.
Old Jun 10, 2007 | 09:13 PM
  #50
Thank you i appreciate that last bit of info! Now i can price everything out to see if its worth it or not.
Old Jun 11, 2007 | 12:42 AM
  #51
titter's Avatar
http://www.bailey-eng.com/LTCC.html
"Benefits of the system are: extended opti life much stronger ignition at high RPM/boost built in adjustable rev limiter / two-step built in adjustable N2O / boost retard."
Old Jun 30, 2007 | 11:22 PM
  #52
My MSD box is a DIS-4. You can't use a MSD digital 6 with a delteq or LTCC system. The two small red boxes on the plate are MSD digital tach interfacers.
