What does this code mean??????
Old Jun 6, 2007 | 02:52 PM
jeenyus's Avatar
Default What does this code mean??????
Mass or Volume Air Flow Circuit Malfunction- P0100
I scanned my car and this is what came up
Old Jun 6, 2007 | 03:18 PM
stroked383z's Avatar
prob means you MAF is shot!
Old Jun 6, 2007 | 06:21 PM
jeenyus's Avatar
could this cause the car to not want to start??
Old Jun 6, 2007 | 07:01 PM
krayzie7th's Avatar
i would think your car will still start but it probably will just die as soon as it starts, or it will just run real rough.
Old Jun 6, 2007 | 08:20 PM
The LT1 That Could's Avatar
Unplug the MAF sensor, and see how this affects the problem....and then post back up
Old Jun 6, 2007 | 08:57 PM
Silver97TA's Avatar
oh maybe thats my problem. my car will start but then die right away. it runs pretty ruff when i can keep it running. could a bad EGR valve cause the same problems???
Old Jun 6, 2007 | 09:38 PM
Ralls's Avatar
A bad EGR valve can cause it to stall on you too. As if the EGR valve is open at idle. But follow the MAF problem since you have a code, unless you know something we don't. Check your volts at the MAF connector. It's not 100% that the MAF could be shot. It could be the wiring. MAF's are too expensive to find out your's might be okay in the first place.
Old Jun 7, 2007 | 02:54 PM
ebay & the parts FS section here - MAFs go for about $50 used
Old Jun 14, 2007 | 12:59 PM
jeenyus's Avatar
When i disconnected the maf the car fired up. then went to drive it this morning and the car fired up then shut off. I just changed the fuel pump also
