Which head gasket?
Old Jun 21, 2007 | 09:49 PM
BLACKSHARK's Avatar
Default Which head gasket?
What would be the best head gasket to use on a 94 lt1 that is putting roughly 350-400rwtq down with stock heads?
Part number too, if you have it?
Old Jun 22, 2007 | 09:23 PM
Imnotfast's Avatar
Felpro 1074
Old Jun 22, 2007 | 09:43 PM
speed_demon24's Avatar
Cometic .027" 4.01" bore to get your compression up.
Old Jun 23, 2007 | 01:40 AM
hvyss's Avatar
Look at the Impala head gaskets. They are .029 thickness. I have used them on every build I have done with great results.
HVY SS
Old Jun 23, 2007 | 10:11 AM
the_merv's Avatar
Veteran: Air Force
X2 for the Felpro 1074's. I used them and had no problems.
Old Jun 23, 2007 | 11:14 AM
Burning Rubber's Avatar
I will have to agree with speed demon
Old Jun 23, 2007 | 12:14 PM
Puck's Avatar
HVY SS
I too run the .029 impy gaskets without any complaints.
Old Jun 24, 2007 | 05:04 PM
Tritonium's Avatar
If you use Cometics, Make sure your surfaces are freshly milled as they are designed to be used on speced surfaces.
If this is a garage replacement use Felpro - they are great and are able to fix the minor spaces in an unmilled surface.
Old Jun 24, 2007 | 05:58 PM
DroppedM6Z's Avatar
Impala gasket are discontinued FYI. Your going to have to find a Dealership that has a few in stock. And not Jason @ samtaylor.....i got all theres. I spent the last month looking. Everyone was selling them for 7.xx a piece. Hope you find some if thats what you want.
