L98 shortblock into LT1
At any rate, he has a L98 355 that has yet to find a home just lying around...It's built pretty stout from what i remember...
What we're trying to find out is if the shortblock will work with the LT1 heads and all that top end bullshit...
I know there is a cooling system issue, wouldn't an electric water pump remedy this situation???
What else is needed to make this happen, or any other avenues of cost effective measures to make the car run again...
I know the rotating assembly would swap over with some machine work to the LT1 block, but we're unsure of the damage caused, if any, to the LT1 block...
What do you fine people suggest we do???
Any help might be appreciated
