Mr Spring meet Mr .704 Lift.....
Old 06-30-2007 | 12:58 AM
OutlawZ's Avatar
Default Mr Spring meet Mr .704 Lift.....
Hehehehehehe this is what a Nextec spring looks like under .704 lift on the intake side on my AFR 227's......
looks frikking painful.... Engine builder says there's a lot of room before coil bind.... even though the springs coils look like they're humping each other....
Old 06-30-2007 | 01:46 AM
infinitebird's Avatar
10 Year Member20 Year Member
wow, that's some serious lift for an lt1 cam
Old 06-30-2007 | 03:58 AM
Hot94Z28's Avatar
That spring looks like its saying "Help me"
Old 06-30-2007 | 04:06 AM
Formula350's Avatar
Is that .704 with just the cam or are the lifters factored in as well? And yea that's some insane rocker angle lol
Old 06-30-2007 | 04:12 AM
Revelation Z28's Avatar
damn! gonna need tall valve covers for that
Old 06-30-2007 | 07:09 AM
Tony Shepherd's Avatar
Thats all the lift you have? Ive got ya beat.
Lookin good bro!
Old 06-30-2007 | 07:33 AM
OutlawZ's Avatar
Heheheh yeah the rocker angle is figured iin..... 1.7 intake and 1.6 exhaust.....
I knew you had more duration Tony but you've got 704+ on the intake side????? jesus......
Old 06-30-2007 | 08:43 AM
fast's Avatar
704 got my attention, afr 227's got me so excited my g/f got jealous
Old 06-30-2007 | 10:29 AM
dhdenney's Avatar
What kinda springs are those?
Old 06-30-2007 | 11:04 AM
OutlawZ's Avatar
Those are Nextec pacalloy triple valvespings.... They are an upgrade thru AFR. I believe they are the best ones AFR sells with their heads.... I can't remember the OD on them. But they're good to like .800 lift properly setup... Lance said they measured 275 lbs on the seat....
Oh and he finished my intake welding. He lopped the water neck off of my Victor E, welded up the holes, got rid of the lettering where it said "Edelbrock Victor E" and smoothed everything out and needled it to leave an as cast finish... finished it up yesterday so we're ready to bolt up the intake monday morning.... i'm stoked!
Old 06-30-2007 | 12:27 PM
dhdenney's Avatar
^^^ Dude that's nice. Angle of the pic makes the end of it look like a football field though.
Old 06-30-2007 | 12:36 PM
Speed Density's Avatar
hashtagBMW
The !Waterneck is SWEET
Tony.
Old 06-30-2007 | 03:39 PM
OutlawZ's Avatar
Yeah I can't believe it was ever there from what it looks like.... I did see it go thru the transformation so I know it was there at one point....
but you'd never know from lookin at it.... thanks again guys...
Oh and DH I found out a little more about the springs. They are Nextec springs manufactured by Manley. They are basically a high end version of spring using next generation metals where memory problems with previous springs materials are basically a non issue with these springs. There are a few pro stock engine builders using them. And a few that I know that are running near .900 lift with them without failure. They are an upgrade thru AFR that you can get on their heads.
Old 06-30-2007 | 06:11 PM
speed_demon24's Avatar
Man its nice to finally see some nice LT1's in the works.
Old 07-01-2007 | 11:15 AM
dhdenney's Avatar
Just seems like you don't get to read about those hosscat springs much. Just curious about those.
Old 07-01-2007 | 02:06 PM
OutlawZ's Avatar
There's some good reading on valvesprings if you do a search for "Nextec Springs" in google and go to some of the forums and research the threads there.....
Old 07-01-2007 | 07:19 PM
FASTFATBOY's Avatar
NIIIIICE! I am diggin it dude.
I am gonna run .680 lift in a STREET car.....those kinda lift numbers make me cringe.
More pics please.
David
Old 07-01-2007 | 07:48 PM
matt94z's Avatar
I can't wait to see how your setup runs! Looks awesome
Old 07-01-2007 | 08:39 PM
OutlawZ's Avatar
Here's another one where you can kinda see the manton 3/8" pushrods and where we had the massive clearance issues with the head gasket (gasket holes needed to be clearanced since we're using offset intake lifters)
manifold goes on tommorrow and we'll start mocking up vacuum pump brackets, weld the valve covers for the AN fittings and do some finish work on the front with the accessories. I'll probably put the throttle body on it and the FPR and FPR bracket. We are nearing the finishline thank god... thanks for all the words guys, believe me i'm just as excited about seeing how it runs. From other motors I've seen come out of CSMRE I'm sure it'll be everything i expect it to be...
