LT5 vs GEN I/II/III/IV
I've always wondered what the exact differences in the blocks were. I know plenty about the LT5, I know it's a DOHC 32V engine, 3.9" x 3.66 bore/stroke, etc, but I want to know what made the LT5 engine block different and what made it similar to SBC's. Also what are the advantages/disadvantages in the block design. I can't seem to find any info related to the block design itself.
I emailed this guy, asking for some info, or at least just some block pics.
acsvette (add the normal link items for their site. So the mods don't have a reason to remove a link
I also stumble across this. Alls I can say is good lord. Oh, and notice the starter location LOL I wonder how often THEY fail! Only page 4 is w/o pics, but check the flow numbers on Page 3 :O
http://forums.corvetteforum.com/show....php?t=1490283
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
The guy emailed back with ONE pic :\ Not very good, but it shows how weird the LT5 cylinders are. Image after the edit.
I also stumbled across a LOCAL well know, and very respected shop, DRM. Doug Rippie Motorsports. He was in Motor Trend back in the earl 90s for his Black Widow LT5s.
http://www.corvetteactioncenter.com/...lackwidow.html
Anyways, I wish there were more pics. Those LT5s are nuts. It seems like Lotus didn't stray very far from their own design on that one, or their current ones. Though, theirs are mostly smaller L with more cylinders and turbo![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
![](http://www.arctec.org/~maxpain/lt5.jpg)
yea I don't quite understand if there's ANOTHER sleeve that fits in that open area or what, because it's pretty clear we're looking at from the head deck down into the crank area.
That site I mentioned above, they make 448cid LT5s heh
Originally Posted by the_merv
The upper ends of the Sleeves are missing.
If I am not mistaken..that Bore/Stroke is very close to a LS1..
The merv is right the sleeves are missing.
My machinist (Brian Ebert) builds big bore, stroker LT5s. I watched him making his own sleeves one day. The blocks are totally different than the SBC and due to the low numbers built there is no volume discount when it comes to speed parts. So you have to PAY to play in the LT5 league especiallly in the 400+ CI club.
I love the way LT5s look and sound incredible at speed. But I'll probably buy a C5 ZO6 or a plane jane C6 becuase if I bought a ZR1 I'd have to mod it and they can swallow 10K quicker than Jenna Jameson on a tube steak whereas LSX mods are notsomuch.
If I remember to bring my camara the next time I'm there I'll see if Brian will let me snap some pics of some of the LT5s in the shop.
Mike
![](http://phil.haacked.com/images/phil_haacked_com/WindowsLiveWriter/MovieTime_8EA0/borat_narrowweb__300x495,0%5B2%5D.jpg)
Mike
Well after much research and reading just about every website that has the LT5 in it I also found a website of an engine builder who owns his own company but gave some detailed photo's of disassembling the engine and taking notes of key features.
http://www.bustedcar.com/silverfox.htm
-The block is a two piece design...The main caps are incorporated into an intermediate girdle assembly.
-center oiled crank. oil pump driven by the front of the crank and oil is sent to the crank FIRST, then to the passages in the block.
-cup plugs in the crank centerline.
-The ignition control module and coils are located under the intake plenum.
-Oil pan has a built in windage tray.
-Oil pump pulls oil from the pan through an o-ringed port.
-The starter is also located under the intake.
-The throttle body has a very small third butterfly valve that opens first, then the main throttle blades open.
I can also see that the water jackets differ vastly from an LS1 block to the SBC to the LT5...
