Got damned this overheating lt1
Old Jul 26, 2007 | 02:36 PM
chavez885's Avatar
The 160 degree t-stat will make your hot air during the winter a bit cooler.
Old Jul 26, 2007 | 02:38 PM
dhdenney's Avatar
He's got bigger fish to fry than his heater.
Old Jul 26, 2007 | 02:41 PM
WhyHelloOfficer's Avatar
When was the last time you flushed the coolant?
What is the coolant level at?
How long have your fans not been working?
These are all extremely important things, especially now that we're getting into the heat of the summer.
Old Jul 26, 2007 | 02:46 PM
JTSLP559's Avatar
my car gets hot too.. i see's 235 or so before the fans come on. i have the stock thermy. i hear itl mess **** up if you replace it with anything different then what it came with? any truth to that? if not what thermy should i get to keep it cool? it was sitting for 2 years also
Old Jul 26, 2007 | 02:50 PM
It takes less than 5 minutes to swap to a 160 Thermostat. It won't affect anything, it simply opens up sooner so it lets coolant in more quickly. I'm in Florida so I'm not as concerned with cold starts and warming up in the morning, but I'm yet to hear any horror stories of using a 160 Thermostat.
If the car was sitting for two years, I'd suggest getting it flushed with fresh GM Dex-Cool and ensuring that there aren't any air bubbles in the system.
Some of the biggest cooling system issues with the LT1 cars now that they're getting older is that people who owned them previously would top the cars off with normal green coolant. When you mix green coolant with dex-cool it makes a nice mud. Which if it isn't flushed out, it can rust the radiator and ruin the rest of the cooling system.
Also the LT1 was made to run hot from the factory anyways, to help decrease emissions. The fans aren't set to turn on until 210* (if I remember correctly). A basic tune can fix this as well.
Old Jul 26, 2007 | 03:50 PM
chavez885's Avatar
Close,i think its like 225,but either way. Like officer says,get it tuned or a fan switch.
Old Jul 26, 2007 | 03:54 PM
LT1_freak!'s Avatar
Originally Posted by z28hustle
you could install a manual fan switch that u turn on when u get in the car..
ya i'd do that. that fixed my problem
Old Jul 26, 2007 | 04:48 PM
dhdenney's Avatar
Just a heads up, my radiator was full of calcium deposits and prevented cooling. I had another laying around. However I am fairly certain I can clean it up for future use. If you are stumped with the cooling, make sure your radiator is clear and clean!
Old Jul 26, 2007 | 05:57 PM
the_merv's Avatar
Veteran: Air Force
If I'm not mistaken..the Fans aren't programmed to come on until about 210..and both automatically come on when you turn the AC on.
Old Jul 26, 2007 | 06:37 PM
fireman's Avatar
Originally Posted by That_guy
come on guys what wrong with the car. when we took the elbow and stuff off. The antifreeze was coming out of the water pump.
I'd say the waterpump is bad. Replace it along with a 160* thermostat. Might need to add an opti to that list too.
Old Jul 26, 2007 | 06:49 PM
Cheap Guy's Avatar
Default Using 160 thermostat as band aid...
I read a bunch of threads on a bunch of forums regarding overheating problems with LT1's. IMO too many saw the 160 therm as a band aid. It will help a NON-overheating LT run a little cooler, but it WON'T solve a true overheating problem.
My suggestion is to test the fan, get a pressure check and get a coolant check. None of these are expensive and may actually save you money in the long run.
Old Jul 26, 2007 | 07:04 PM
  #32
supaspowt's Avatar
................................. matter of fact my fans dont even work anymore.
no fans and you ask whats wrong? R U SERIOUS?
Old Jul 26, 2007 | 11:20 PM
  #33
That_guy's Avatar
lol the fans do work actually. i dont kno why they wasnt coming on when it was overheating. we checked everything and he says the waterpump is fine. im bout to drive this **** to see if something happens. wish me luck
Old Jul 27, 2007 | 02:42 AM
  #34
JTSLP559's Avatar
mine dont come on till 235..
Old Jul 27, 2007 | 07:06 AM
  #35
That_guy's Avatar
ok well the car is a lil better i noticed it doest go to 210 fast. But stays in the 180-190ish while cruising. my airconditioner has gotten colder too.
Old Jul 27, 2007 | 08:06 AM
  #36
That_guy's Avatar
Update tested the beast out this morning hehehe on the highway not the street like lastnight. Well temps have gotten a lil higher when im at a stop and it just goes over 220 easily. so its gotten worse a bit. Not to mention there is this lil ticking sound im now hearing.
Give yall opinions on what i should do to get the car cooler. Besides the 160 tstat. trying to make it last a lil longer.
Old Jul 27, 2007 | 12:09 PM
  #37
Bill's 02 Z-28 SS's Avatar
Yet another problem from my car.damn this lt1 lol (dad im sorri but this damn car is givin me problems) well today i was in the drivethru at dairy queen and i see steam coming from my car i turned it off instantly, looked at the gauge and im in the red zone. So after i get my food i go to this big *** parking lot across the street pop the hood and the antifreeze is boiling its *** off right out of the reservoir. I call my boi txhotboi972(member here) too see if he could help me, i told him where i was and he said he will be at the autozone (which is 500 ft away) shortly.
We get there check the car go to my house which i was affraid to do but the car had cooled down abit. (btw his car sounds like a monster big cam) So when we get there he took out the thermostat. He told me to leave it out for awhile and start the car to see if it would effect the temperature or make it cool down a bit. It didnt do anything but make the car worse.
SO these are the ideas that could be causing the car to do this ****.
1.new thermostat
2.Radiator problems
3.Water pump problems
4 The thing that covers the thermostat wont close all the way due to a screw not going in he twisted it and it wont get tighter at all there was some otherstuff he said. But i forgot. But imma try to get more info soon but what do yall think is wrong with it.
Hi Folks
For the past 3 summers the car would over heat big time when in traffic - it would not take long to get hot, almost into the red. Had to shut the AC and turn on the heat to cool the car down while driving - not fun. Anyway to make a long story short, had a water pump leak - small but enough to hose my Optispark unit. So replace the water pump and the unit, to my surprise the car ran cool - never go hot again, does not go pass the center on the gauage in heavy traffic and on hot days 90+. I was shocked on how cool it runs now - never thought it was the water pump - tried everything else until this happened. Depending on the mileage - I would change the water pump if you tried everything else. By the way I am running a 160 thermostat.
thanks
Bill
Old Jul 27, 2007 | 03:54 PM
  #38
JTSLP559's Avatar
my waterpump is brand new.
Old Jul 27, 2007 | 11:16 PM
  #39
67SS&99SS's Avatar
That_guy, I think you need a new waterpump. I've gone through the cooling nightmare with my uncle's LT1. I replaced all of the fan relays first, that did nothing. I thought the car may have been leaking coolant, so I checked all the hoses, and one of them had a crack in it. A few minutes later, it toasted the opti. Since I haven't had much experience with LT1s, I let my mechanic put a new opti on and told him about the issue with it running hot. He checked the waterpump out and it had took a complete dump. After putting that on, the car runs around 180-185* all day long. How many miles are on your car? My uncle's had around 111,000 on it the waterpump was replaced.
Old Jul 27, 2007 | 11:31 PM
  #40
transambandit's Avatar
Might want to flush the system then make sure you bleed it, you can get hot pockets of air that cause the engine to run hot, there are 2 screw valves that open up and release the air in it.
http://shbox.com/1/how_tos.html
Good site that tells you a lot about our cars.
