Got damned this overheating lt1
Old Jul 29, 2007 | 06:55 PM
  #61
93 blackformy's Avatar
I thought water pumps don't jus break without leaking or bussing or showing some sign visually or whatever....someone correct me on this!
Jon-
Old Jul 29, 2007 | 06:56 PM
  #62
Originally Posted by seawolf06
If your radiator is the original, then the cores could have gone bad in it as well. You can go with the ewp if you want, but get the radiator checked out at the same time.
Thats what I was thinking mabe the radiator!!
Old Jul 29, 2007 | 07:06 PM
  #63
Matts94Z28's Avatar
True, before i had the issues with the hoses i had to replace my radiator simply because it was old and didn't cool well. I completely forgot about that...
Old Jul 29, 2007 | 07:09 PM
  #64
dhdenney's Avatar
Originally Posted by That_guy
And the hoses are just fine. But that idea will be tested out.
Nothing to test! Just go look!
Old Jul 29, 2007 | 07:18 PM
  #65
That_guy's Avatar
my waterpump was leaking the last time. im bout to do some tests real quick.
Old Jul 29, 2007 | 10:24 PM
  #66
NovaTodd's Avatar
Jon-
Mine broke the impeller off of the shaft - no noise or any other indication of failure other than the temp guage going completely in the red and the ensuing blown head gasket...
Pulled the pump and removed the cover and the impeller fell out.
Old Jul 29, 2007 | 10:44 PM
  #67
Yea I was thinking about that but thought it'd be kinda rare....but I guess if it can happen it will lol.
Jon-
Old Jul 30, 2007 | 07:09 AM
  #68
Bill's 02 Z-28 SS's Avatar
Hi Folks
If it isn't the water pump and the system looks good, then it will air in the system - need to burp it many times, blown head gasket or cracked head. Before I went down this path, I would pull the water pump to make sure – more than likely – it is a rebuild and who knows it works well. I thought my water pump was good and when I changed it what world of difference. Just my two cents
Thanks
Bill
Old Jul 30, 2007 | 09:19 PM
  #69
transam5.7lt1's Avatar
Check the spoiler upfront if it overheats on the highway, make sure BOTH fans DO work. If everything else fails... you might have a little crack on a head, might be too little and small that it won't make oil milky, but it will force air into the cooling system thru that little opening, as if the engine hasn't been bled properly... as a result = OVERHEATING!
Old Jul 30, 2007 | 09:39 PM
  #70
86zboss's Avatar
My car would overheat w/ both fans going. not to bad though. I just had a msd dist put in and when they pulled the water pump off the bearing in the back was a mess. missing like 4-5 *****. Then we took the front cover off and the impeller was rubbing along the inside. There was a lot of "play" in it. Only 75,000 miles too! But that was my problem, no water was moving through the pump. Replaced it and good as new.
Old Jul 30, 2007 | 11:41 PM
  #71
That_guy's Avatar
what water pump should i get. i cant get the electric fan wish i could mom wont allow it lol for some reason.
Old Jul 31, 2007 | 10:04 AM
  #72
dhdenney's Avatar
Stock replacement, no discussion needed.
Old Jul 31, 2007 | 12:14 PM
  #73
Totally agree I would not get a rebuild - new ones are cheap. Also folks, the fans are cut off after 40 mph - if have problems after 40mph, the fans are not the issue.
Old Jul 31, 2007 | 04:52 PM
  #74
blk97z28's Avatar
If he were to get it tuned what would be a good temp to have the fans come on at?
Old Jul 31, 2007 | 05:55 PM
  #75
indirocz28's Avatar
Probably about 150*F coolant temp.. - Also- why not just put in a new pump and 160 thermo.. then tune the pcm for 150 and you shouldnt have any problems..
Old Jul 31, 2007 | 11:23 PM
  #76
That_guy's Avatar
getin a 160tstat tomorrow
Old Aug 1, 2007 | 06:30 AM
  #77
koolaid_kid's Avatar
My fans are set as follows:
Fan 1 - 170
Fan 2 - 180
Old Aug 1, 2007 | 08:29 AM
  #78
indirocz28's Avatar
Fan 1 - 170
Fan 2 - 180
George, does your software do the temps in *F or *C?
Mine only does it in *C
So i had to go find the calculations and then each time I wanted to know what the other was i had to convert it..
Is there any way you could make up a simple calculator file that just does *C to *F?
And then maybe another one that does KPA to PSI and vise versa??
Old Aug 1, 2007 | 10:10 AM
  #79
dhdenney's Avatar
Damn the rest of the world and their metric!
Old Aug 1, 2007 | 10:38 AM
  #80
mikex70's Avatar
Hey bro make sure ALL the AIR is out of your system, I was having bad overheating problems, Overflow in the red Zone kind of the same as you and it took 6 weeks before i got all the air out of the system, Keep checking the Air Bleeder Lines and get a stead flow of coolant so you know you got most of the air out, try not to go to crazy and take it step by step or TAKE IT TO A SHOP lol, Check this link to see how to bleed the system
http://shbox.com/1/4th_gen_tech2.html#cooling
