Got damned this overheating lt1
Yet another problem from my car.damn this lt1 lol (dad im sorri but this damn car is givin me problems) well today i was in the drivethru at dairy queen and i see steam coming from my car i turned it off instantly, looked at the gauge and im in the red zone. So after i get my food i go to this big *** parking lot across the street pop the hood and the antifreeze is boiling its *** off right out of the reservoir. I call my boi txhotboi972(member here) too see if he could help me, i told him where i was and he said he will be at the autozone (which is 500 ft away) shortly.
We get there check the car go to my house which i was affraid to do but the car had cooled down abit. (btw his car sounds like a monster big cam) So when we get there he took out the thermostat. He told me to leave it out for awhile and start the car to see if it would effect the temperature or make it cool down a bit. It didnt do anything but make the car worse.
SO these are the ideas that could be causing the car to do this ****.
1.new thermostat
2.Radiator problems
3.Water pump problems
4 The thing that covers the thermostat wont close all the way due to a screw not going in he twisted it and it wont get tighter at all there was some otherstuff he said. But i forgot. But imma try to get more info soon but what do yall think is wrong with it.
1.new thermostat
2.Radiator problems
Have you already swapped the oh so shitty stock thermostat to a 160? And its not a good thing that fans ARENT working a car that is so inclined to overheating.
So did taking the stock thermo out help any? If so, then you need to replace it with a 160 at autozone ($15)... Then get those damned fans working...
-justin
-justin
maybe the thermostat, which would be good to change anyways, but i think unlikey. is the water pump leaking out of the weep hole underneath it? that's the first sign of a bad pump. it's not good that the screw is stripped out and not making a proper seal either. when you fill the system, are you opening up the little air release screw at the highest point of the system? its on the hose going to the top of the pump. you want to open it as your filling the system, and when water starts to come out, screw it back down....it allows all the air to escape the system to prevent air lock. I've gone through 2 water pumps and the whole overheating, boiling water thing too..lol...just a few things to know that might help. good luck!
If your fans are not working, you will overheat, especially while sitting in the drivethru. Get them working and I suspect your problems will go away. Voice of experience; I caught a plastic bread wrapper in one of mine, which burned out the motor. While driving it was O.K., but while sitting idling it would overheat. And this was with one fan; with no fans it would have been much worse.
YUP- these cars need air BAD. You can get a tune and lower the fan on temps..
Mine are just hotwired so they stay on all the time.. even on the hottest days - with my car with a 180 thermo my car doest get above 194...
You kinda answered your own question. If your fans dont work, that is why you are overheating. There will be no airflow over the radiator when sitting still, that is why the fans are needed.
Originally Posted by That_guy
ok need new fans and a thermostat. and the antifreeze was coming from above the opti where the thermostat should be
ok cool so how do i hotwire them and they went out when i had the air on.
Hahahaha no the **** im not friends with him lol. that 6 cylinder faster cause of it bein lighter was funny as hell tho.
Btw i was goin to get a 160 tstat but my uncle was like the car is designed to use the parts it came with. makin it run colder will **** some **** up. i didnt want to argue with him but a 160tstat is better than a 180 replacement right.
