355 ci
Old Jul 28, 2007 | 04:14 PM
scorpion_z28's Avatar
Default 355 ci
I notice alot of cars with this set up,i've never seen this assembly kit anywhere??is there something special about it & where can i get it from?
Old Jul 28, 2007 | 04:39 PM
Red96TA's Avatar
i thought it was just a .030 over 350 block?
Old Jul 28, 2007 | 04:50 PM
dangalla's Avatar
bang!! there ya go
Old Jul 28, 2007 | 05:16 PM
Originally Posted by dangalla
bang!! there ya go
will it make a big difference in HP?
Old Jul 28, 2007 | 05:22 PM
95FbFormula's Avatar
not really usually people go with forged pistons and rods and higher compression when doing a 355 then porting the heads
Old Jul 28, 2007 | 05:34 PM
Speed Density's Avatar
hashtagBMW
The 6in Rod/Piston selection is one of the best for our engines, it works very well together.
Tony.
Old Jul 28, 2007 | 05:54 PM
396D1SS's Avatar
It might add 2-3 hp but the main purpose of a 355 is to bore the cylinder walls and make them true again so the rings seat good and it makes good compression
Old Jul 29, 2007 | 03:40 PM
Tony.
Could you provide me with part numbers for the rods & pistons im thinking of doing it in the next rebuild.
Old Jul 29, 2007 | 03:42 PM
Revelation Z28's Avatar
if i keep this im going with an un forged 355 with the 6.0 rods.
355ci is just a clean off shave of the cylinders. when you go to 364 (6.0) or 383 or 396 THEN youre talking 20-40hp.
Old Jul 29, 2007 | 03:52 PM
This sounds even better.
