2 foot flames?
Old Jul 30, 2007 | 10:11 PM
93blacktransam's Avatar
Default 2 foot flames?
Hey i have a 93 trans am lt1 , gm hotcam lt4 intake mannifold, 52mm throtle body ,stock injectors tbi tune , long tube headers, and flowmasters 40's.
I have recently been shooting 2 foot flames out of my passenger side muffler wich is stright to the header no cats or anything,but anyways and also small flames coming from between my black and header flange. someone said it was becasue the valves were not set right . but i tried to set them wich was my first time and it still does it and my car is running like crap someone please help me asap its my daily driver.
Old Jul 30, 2007 | 10:32 PM
also when i bout the car and did the engine swap the plug on the trans mission had the 5 wires stripped out but the wires and plug are still there just not hooked up the 5 prong plug has letters a threw e where the wires go in .and it will only go 1 threw 4 gears and no overdrive.hard shifts.Can anyone help me find out wht color wire goes in wich hole or have a diagram.
Old Jul 30, 2007 | 11:00 PM
donkey mule's Avatar
I say burn the tail gaters!
Old Jul 31, 2007 | 01:40 PM
Come on anyone someone has to know whats wrong.
Old Jul 31, 2007 | 01:56 PM
FASTZ2895's Avatar
I would say your valve on that side are bad. You should do a valve job on both heads or buy some after market ones. Like AFR's or Trick flow
Old Jul 31, 2007 | 06:59 PM
anyone else couldnt it be something else tho maybe a bad plug ot my opti
Old Jul 31, 2007 | 09:29 PM
the_merv's Avatar
Veteran: Air Force
Valves are too tight, or one is bent, but I am goin with too tight..
Get some Video of that ****..
Old Jul 31, 2007 | 10:42 PM
hyperzone's Avatar
a must see!
+1 to valves not seating correctly, but I'm no expert.
Old Aug 1, 2007 | 05:43 PM
camar0corey's Avatar
I've had two cases in life when my vehicles have shot flames.
1st case, 86 2.8 Camaro, 5800rpm no lift shifts, had a little valve float. Guy in Honda asks if I have nitrous. Yeah it was shortly after F&F came out.
2nd case, 94 Z28, bad opti, lots of uncombusted fuel=fireballs.
Um neither sounds like what you have going on. Except the valve part.
Old Aug 2, 2007 | 08:26 PM
well i losend the exhuast valves and it runs great but still horrible back fires and flames
Old Aug 2, 2007 | 11:07 PM
ZONES89RS's Avatar
In-Zane Moderator
LOL!!! Mine does it, flames outta both sides when i down shift, but runs great, mine should do that with straight pipe and no cat due to unburnt fuel downshifting, yours on the otherhand....somthin fucked.
Old Aug 14, 2007 | 10:20 PM
ok now what the hell i took out my rear passenger side plug cleaned it and now no poping?
Old Aug 14, 2007 | 10:24 PM
ZONES89RS's Avatar
In-Zane Moderator
Well then it is burning more fuel with the spark rather than burning the unburnt fuel in the exhaust, no biggy, u did good.
Old Aug 14, 2007 | 10:46 PM
really lol but acordint to that one dude im a dumb as 17 year old who doesnt know my ***** from a hot dog lol
Old Aug 15, 2007 | 12:46 AM
ZONES89RS's Avatar
In-Zane Moderator
Hmmmmm...id hope you would know the difference or you might not have kids.
