Golen 383 Dyno results inside
58mm BBK
#30SVO
Port mached intake
Trick flow LT1 heads, Ported by Willie Bell of Washington NC
Pro Mag 1.6 on a 7/16 stud
Golen Comp Short Block 383
Golen Cam
Pacesetter LT/ORY
Mcloed ST Clutch
Deltec with MSD Dis 4
!everything else
if you get a sound clip for that please post it up... id love to hear it... im thinking of using a golen engine for my project once i start working on it... i might use one of their long blocks tho... im liking the numbers you got... good luck with that man...
auto or M6? I'd also like to know why you only rev to 5900....where's the cam degreed at?
The reason I ask is cuz I'm looking at almost the same setup, but more compression and a very similar cam most likely retarded a few degrees from where you have yours, but hope to make about 35 hp more to the tires. I'm just trying to get an idea....
The Car was only run to 5900 because on that run the Rev limiter on the MSD was set to 6000, and thats the pull where the car made the most HP. when we pulled the MSD to 6500 the car didnt make any more power so he didnt give me those graphs. I asked him about them today and he is goiing to email me the rest of the runs monday.
Pete
Pete
As I admitted, I need to get back in the saddle and drive this thing. she was down about a year befor this. When I get back from my 7 month vaction to the desert Ill put some sticky tires on her and I have a few other things sitting in my garage that should help my launch. Anyways here is best timeslip
RT.....1.27
60ft...2.21(Kumo's Suck)
1/8....8.68
1/8....86.50
1/4....13.1601
1/4....110.79
The clutch didnt slip it was all tires, Im running a McLoed street twin.
RT.....1.27
1/8....8.68
1/8....86.50
1/4....13.1601
1/4....110.79
