Normal compression test #'s
Old Aug 24, 2007 | 05:17 PM
derekderek's Avatar
Default Normal compression test #'s
Just wondering what stock compression numbers should be? I did a compression test today with a cold motor and I got 155-160ish across the board. Just wondering if those are ok numbers. I tried searching but it wasnt working very well. Thanks for the help.
Old Aug 24, 2007 | 05:30 PM
krayzie7th's Avatar
they seem good to me.
Old Aug 24, 2007 | 05:32 PM
SLawson86's Avatar
sound about right to me also
Old Aug 24, 2007 | 05:45 PM
derekderek's Avatar
Thankyou! I was getting scared finally search worked for me. All the post I was seeing they said there # were near 200# but these were 2000 and up cars. This is a 96 Z28 with 119,000 miles on it. Glad those # seem good!!!
Thanks
Derek
Old Aug 25, 2007 | 12:18 AM
96capricemgr's Avatar
Did you have the throttle blocked open?
Frankly consistent numbers is most important but that said those numbers are quite low but it could just be the gauge.
My wagon at 180K cranked 200psi and my Caprice with the milled heads and thin gasket for 11.2-3:1 compression cranks like 230psi.
On an old low compression gen 1 135-160 might be fine but on an LT1 I do not think so.
Old Aug 25, 2007 | 10:52 AM
derekderek's Avatar
Yes the throttle was open. Maybe if the engine was hot the numbers would have been higher. And this was done with a cheap 5$ gauge so who knows. The car runs good ran a new best last night 12.6 at 111mph Only mad 2 passes got there to late. I think with more practice I can get a low 12 maybe high 11. Well thanks for the info.
Derek
Old Aug 25, 2007 | 11:29 AM
LittleRedZ's Avatar
Derek
sounds like your car runs well, whats done to it?
oh yeah btw 12.6 is a decent trap for 111mph if its a 6speed car, you def not touching an 11sec anything with 111mph trap speed.
Old Aug 25, 2007 | 12:06 PM
derekderek's Avatar
It has LT headers dumped before the axle, CAI , Wally 225, Nitrous express kit, Spec stage 3 clutch , lighten flywheel, 160 thermostat , And 350-400 pounds of weight reduction! And some suspension work done. Well the 12.6 I bogged of the line still trying to find a good launch rpm with the new ET streets. I know I have a low 12 in it. I also have 4.56 gears waiting to be put in. And if I put Skinny's up front instead of the 275's ZR1's up that should help. Any suggestions? Thanks
Derek
Old Aug 25, 2007 | 12:15 PM
buffman's Avatar
I would fully warm the engine up if you want more accurate numbers. I was seeing averaged out 205-210 on my 167k engine. Iron heads so the compression is a touch lower than with AL heads.
Old Aug 25, 2007 | 12:32 PM
LittleRedZ's Avatar
Derek
yeah spray it more you need another 3-4mph to get to 11s that if you get a 1.6 or better 60ft. Get a set of rockers that should pick you up a mph or two and an electric water pump, get a tune from PCMfor less you would be close.
good luck
Old Aug 25, 2007 | 12:48 PM
derekderek's Avatar
good luck
What rockers do you recommend? Electric water pump is already on the list I figured I would wait till the opti started showing signs of going out! As for spraying more don't think it would help that much I still need to perfect my driving with what I got now. No need to rush and blow things up just yet .
Derek
Old Aug 25, 2007 | 03:13 PM
dhdenney's Avatar
I've got a question. How would you suggest threading a compression gauge into 8 spark plug holes on a hot engine? As tight as it is in there, I don't see myself getting one cylinder done without burning the **** out of my hand.
Old Aug 25, 2007 | 03:32 PM
buffman's Avatar
well not a red hot engine. One that's warm will work just fine. If you have headers there should be a little more room in there
Old Aug 25, 2007 | 03:50 PM
dhdenney's Avatar
No thanks. I'd rather do a cold engine and just use the numbers for comparative purposes.
Old Aug 26, 2007 | 11:29 PM
SLawson86's Avatar
im with the above. i use the numbers cold just to get a ballpark average. if you were really concerned with an individual cylinder, then do it warm. just my two cents...
Old Aug 27, 2007 | 01:42 AM
Formula350's Avatar
Those who don't care about doing it with a warm motor, do us a favor and run the tests twice. Once on cold, once on warm/hot, so we can get the % change and apply it to our cars
Old Aug 27, 2007 | 02:24 AM
ZONES89RS's Avatar
In-Zane Moderator
Just a side note, the newer motors LSx have a wider LSA in the factory cam, it causes less bleed off so the static compression is up there too, it is just another reason they make more than older motors.
