Video/Soundclip of 388 Ci Stroker LT1
15,000 Miles
Here is the list of parts/mods to engine/tranny and what would come with engine.
New Wiring Harness
2 PCM's
-Eagle Nodular Iron Crank 3.750"
-LT4 Knock Module
-Hurst Short Throw Shifter
-TB Bypass
-Walbro 255lph Fuel Pump
-Holley Adjustable Fuel Pressure Regulator
-Lucas 42# Fuel Injectors
-5.7" Powdermetal Rods
-KB Hypertectic 383 Pistons 4.060"
-Milodon Full Windage Tray
-Hastings Racing Rings
-Clevitte 77 Racing Bearings
-Comp Cams 468 Xtreme Fuel Injection Cam .579/.584
-1.6 Ratio Magnum Tip Roller Rockers
-Comp Cam Magnum Push Rods
-LT4 Hydraulic Roller Lifters
-Pacesetter LT Headers
-K&N Air Filter
-Ported MAF Sensor
-GM Performance Timing Set (new)
-Cloyes Double Roller Timing Chain (new)
-Rebuilt T-56 (great but still needs 3rd/4th slider)
-180 Thermostat
-Air Foil
-Copper Header Collector Gaskets
-Copper Header Gaskets
-Crane Cams 10308 Valve Springs
-No AIR
-No A/C
-Skip Shift Delete
-6,500 Rev Limit
-No Governor
-No EGR
-No Cats
-Castrol Syntec 10w30
-LG Performance 2.5 in. Lowering Kit
-ES Motor Mounts (ES = Energy Suspension)
-Melling HV Oil Pump
-7QT Oil Pan w/ Milodon Pickup
-Ported and Polished Heads
-Valve Job
-Ported and Polished Intake
-Ported and Polished Throttle Body
-Valve Locks
-Computer dyno tuned
-Autolite XP Iridium Plugs (new)
-LS1 Ram Air Conversion Intake
-MSD Coil Pack
-March Underdrive Kit
-Chrome valve covers with breather
-ARP Rod Bolts
-ARP Cam Bolts
-ARP Oil Pan Bolts
-ARP Main Stud Kit
-Pioneer Head Bolts
-Oil pan has skid plate, extra pan included
-Powerbond Keyed Balancer Hub (new)
All the following parts are new and just replaced:
ICM
MSD COIL
MAP SENSOR
WIRING HARNESS
ALTERNATOR
BALANCER HUB
TIMING SET
PLUG WIRES
PLUGS
OPTISPARK
OPTISPARK HARNESS
o2 SENSORS
o2 EXTENSIONS
TEMP SENSOR IN WATER PUMP
CRANK SENSOR
New Wiring Harness
2 PCM's
-LT4 Knock Module
-TB Bypass
-K&N Air Filter
-Ported MAF Sensor
-180 Thermostat
-Air Foil
-No AIR
-No A/C
-Skip Shift Delete
-6,500 Rev Limit
-No Governor
-No EGR
-No Cats
-Valve Job
-Valve Locks
-MSD Coil Pack
-ARP Rod Bolts
-ARP Cam Bolts
-ARP Oil Pan Bolts
-ARP Main Stud Kit
-Pioneer Head Bolts
ICM
MSD COIL
MAP SENSOR
WIRING HARNESS
ALTERNATOR
BALANCER HUB
TIMING SET
PLUG WIRES
PLUGS
OPTISPARK
OPTISPARK HARNESS
o2 SENSORS
o2 EXTENSIONS
CRANK SENSOR
