1LE Elbow
Old Sep 3, 2007 | 12:17 AM
Pntbll309's Avatar
Default 1LE Elbow
Any of you guys custom fab your OEM one into an 1LE? Im in the process of doing mine right now (boredom). I was wondering if any of you have done it.
Old Sep 3, 2007 | 12:38 AM
transam5.7lt1's Avatar
I didn't make one, but I did buy an aluminum from ebay a while back, it was a very nice piece, I no longer have an LT1, but I remeber that it came with silicone couplers, clamps and a good price for the item, it was a company called CRT Performance or something like that.
Old Sep 3, 2007 | 01:05 AM
Formula350's Avatar
I did. I cut off the end of a V05 shampoo bottle and crammed it in there, then put a hose clamp around it I'm sure adding some silicone around it would help the MAF guys if it does leak. Running SD I could've cared less. I then found my vortec alu one and that's on now.
Old Sep 3, 2007 | 01:35 AM
95 Z28's Avatar
I was hoping I wasn't the only guy that did that ...worked like a charm.
Old Sep 3, 2007 | 01:52 AM
Formula350's Avatar
There was a site explaining a way to do it just like that, but I didn't have the one they listed lol Suave or something *shrug*.
Old Sep 3, 2007 | 01:53 AM
Pntbll309's Avatar
I was reading about the bottle trick. I had to do a makeshift one.I trimmed 90% of the flange where the tube was off. Then took the tube (resinator?) and cut that into a piece, which filled the whole, and sealed it with some RTV. It hasnt dried yet, but I hope itll work. If not Im going to walmart for some V05!
Old Sep 3, 2007 | 01:54 AM
Pntbll309's Avatar
Pert Plus.
Old Sep 3, 2007 | 01:57 AM
Formula350's Avatar
Ah, I knew it was a common brand I was using V05, and it was easy, plus it fit well. I'll snap a pic and upload it here in a min or two.
EDIT: Ah, that's right. It fit so tight I didn't need to use a hose clamp. I just pushed it in as hard as I could and got it flush with the inside of the elbow so it wouldn't cause any air flow restrictions or turbulence.
Old Sep 3, 2007 | 02:56 AM
ZONES89RS's Avatar
In-Zane Moderator
Wow....you guys know a cap from a paint can will work right? Mine is even black and i bet every one of you guys got one laying around
Old Sep 3, 2007 | 09:27 AM
Formula350's Avatar
I rather use this method, personally.
Old Sep 3, 2007 | 10:17 AM
ZONES89RS's Avatar
In-Zane Moderator
Which? Paint cap or shampoo bottle? I bet the shampoo bottle has a cleaner feel in throttle response
Old Sep 3, 2007 | 10:20 AM
Formula350's Avatar
lol Yes the shampoo bottle. I just like the fit better. While a cap wouldn't be bad, it's the rubber and oval fit that just steer me away. If it was a round hole to begin with, I'd consider it. It's just the shampoo bottom fits VEEEERRY tight, and I know it won't suck in, or fall out.
Old Sep 3, 2007 | 10:30 AM
ZONES89RS's Avatar
In-Zane Moderator
Man, i had to force the **** outta my cap, if it was to fall out somehow then the elbow melted somehow, it evem formed with the oval too.
Old Sep 3, 2007 | 12:20 PM
Pntbll309's Avatar
Mine should be all dry and ready to go, Im gonna go test it and let yall know how it worked.
Old Sep 3, 2007 | 01:28 PM
1bdbrd's Avatar
This is the way I went. Just shy of 80 bucks shipped and I got an elbow AND an air foil with install kit. Good stuff too.
Old Sep 3, 2007 | 03:05 PM
Pntbll309's Avatar
Well I got my new fuel filter put in (50k miles old ) and put my new/old elbow on. I didnt notice anything except a little bit better throttle response. But if it helped, then it was well worth the 10 minutes I spent on it.
Old Sep 3, 2007 | 08:40 PM
Formula350's Avatar
I just put my fuel filter in after 96K miles and WEEE I can notice it lol
Old Sep 3, 2007 | 10:53 PM
Pntbll309's Avatar
I cant keep my foot out of mine, so my mpg sucks ***.
