Singal plane help need guys..
Nick
My car was making good torque Through a 4L60E and a 9 inch down fairly low in the rpm range, Has a good flat powerband. It made that power with two wounded pistons....with a six speed and a 10 bolt it would have easily made 510+ to the wheels on pumpgas through a FULL exhaust all the way out the back capped up.It has a super vic conversion, elbow and a monoblade.
David
Oh the hogan looks as bad as the stock intake for air distribution so i went another direction..
I would interested to see a comparison between an Elbow and 4 barrel TB on the same intake I'd even offer my Sheetmetal elbow and Accuafab 105mm for use if there is someone who is willing.
Even a test between the differetn elbows would shed some light. Wilson makes a coulpe different styles now, and there is quite a few people making sheet metal Elbows as well.
As far as usign the Accufab Ford style stuff I emailed the Tech guys at Accufab and got some good info. You can use your stock LT1 syle IAC with their IAC adapter P/N IACGM-2. You will have to swap a couple wires and possibly the plug and run a 87-92 Mustang TPS. The small adapter is 75 bucks from their site but I have seen them around 60 bucks at online speed shops. A new TPS is less 40 dollars.
And a shamless plug for accufab, the customer service is fantastic, answered all my questions and were super fast to respond to my emails.
I ran the GM IAC with the accufab adapter. I dont know how the whole throttle tip in and other problems are though, yet. Havent driven the car.
I really wanted to run a 4 hole type TB to avoid the tip in problems, but air cleaner clearance. I have DFI so I should be able to tune around the tip in problems.
One big thing that hasn't been talked about in this thread is Nitrous use. A single plane setup OPENS UP YOUR NITROUS OPTIONS in a huge way. No more LT1 specific kits which are $700.00+. You can run just about ANY 4bbl kit, there are hundreds. There are tons of different plates you can run too.
Pictures??
I posted the huge pics in the beginning of this thread. Those pics are of a friends car with an Edelbrock Victor EFI manifold. I am running the pro-products version. My elbow is slightly taller, because I am running a 4" cowl hood. It looks virtually identical though. The pics I posted were of the first one my buddy made, and he designed it to fit under a stock hood, with mine he went a little taller.
Hey guys. Does anyone have a link or a contact for a LTX Sheetmetel intake set up?
I have been looking for someone like Beck (still cant find there Company info!anyone?) to fab a singal plane sheetmetel intake. Or should I look at running an Edelbrock Victor EFI type setup? I have an GM LT4 intake and AFR LT4 head setup with and ASM Mono now. Just want to be sure I'm not leaving a buch of power on the table staying with the GM LT4 intake.
Thanks
Ross
Yes, you can get them new for $40 but when you have other costs like the IAC adapter, silicone, charge piping... the savings is worth it.
Tony.
