GM847 and similar
What cam should i go with? I have a 3000 stall, and would be fine shifting at 6400-6500 rpm......
thoughts?
thoughts?
The 242/248 would definitely make more power but you don't want to use that on stock heads.
I've been told the GM 847 makes great power, but the question is where? Where in the RPM range does the power peak? Does anyone have a dyno graph of this cam on stock heads?
I'm going to be running a stock but rebuilt ci motor with otherwise stock heads, mild porting just to clean them up. That is atleast until next spring until I can buy a set of either Trick Flows or AFRs.
Would it be ok to run this big of a cam with 1.6 RRs and 918 springs on a other wise stock but bolt on motor? Or should I find a custom grind?
