doesnt it bug you when.......
Old Oct 2, 2007 | 11:46 PM
HIZPANICGUY21's Avatar
Default doesnt it bug you when.......
doesnt it bug you when you have your key in the ignition (not on) and you have the driver side door open it makes that stupid "DING..DING..DING" noise or whatever it is? i especially hate it when im washing my z and getting around to drying it and i want to listen to some music and that "DING..DING..DING" noise gets on my f-ing nerves. is there any way of deleting this "DING..DING..DING" CRAP ..someone help me. my car is a 97 m6. thanks
Old Oct 3, 2007 | 07:30 AM
ThoR294's Avatar
haha. mine doesnt work
Old Oct 3, 2007 | 07:38 AM
3pnt4maro's Avatar
hmm Im interested as well but it is a good reminder when I leave the lights on..is there any way to delete just the door "dingy"
Old Oct 3, 2007 | 08:32 AM
cruzin94's Avatar
yea take ur keys out or the ignition and get a boom box...haha ....no i would also like to know how cause that thing pisses me off
Old Oct 3, 2007 | 08:51 AM
1SlowFormula's Avatar
I never did it on my f-body but when I was younger, I was the same way and wanted to get rid of it too. One that car there was a button inside the door frame area (between the hinges) that's pressed in when the doors was closed. I just found the wires going to that button and put a little toggle switch on them that way when I was listening to the radio with the doors open I could flip that switch and kill the power to the buzzer, when I wanted it to all work normally I flipped my toggle switch back...
Again I haven't done this on and f-body, but is should be the same principle. You just need to find if the current switch cuts power when closed or open and add your toggle switch accordingly...
Or you can go getto and duct tape the button closed...
Old Oct 3, 2007 | 10:47 AM
dhdenney's Avatar
You can turn your car to ignition rather than acc and the ding will shut off. Of course the fuel pump is on, but I am not sure if there are any consequences to leaving it on without actually running the engine.
Old Oct 3, 2007 | 10:51 AM
ZONES89RS's Avatar
In-Zane Moderator
You do have to admit, there are some retards that need that thing tto prevent them from locking their keys in the car. My wife for example.
Old Oct 3, 2007 | 11:29 AM
alconk's Avatar
Leave the door open while it dings and look for the sound underneath the dash and eliminate it.
Old Oct 3, 2007 | 11:37 AM
Formula350's Avatar
Or just snip the wires(or unplug) to the two push buttons on either side of the car on the inner door well (on the body). That way it just removes the door ding and not the key-in-ignition or lights-on ding.
Old Oct 3, 2007 | 12:10 PM
dhdenney's Avatar
This will kill the lights when the door is open though.
Old Oct 3, 2007 | 01:49 PM
FAD2BLK93's Avatar
PLEASE...do it the correct way, pull the lower panel under the steering wheel and pull the module...not that hard. Listen for the ding and pull it out.
Old Oct 3, 2007 | 02:01 PM
scottso's Avatar
Whew, this post was just in time. I was just about to start smashing things with a hammer until it stopped.
Old Oct 3, 2007 | 09:56 PM
B4C_LT1's Avatar
roll the windows down lol
Old Oct 3, 2007 | 10:29 PM
daniel6718's Avatar
the fuel pump wont stay on it only comes on for a few seconds when the key is on ignition
Old Oct 3, 2007 | 10:34 PM
94greencamaro's Avatar
have you tried pulling your key out a little bit?
works for me......key has to be a little worn though. it didnt work on my new key until about a month or so.
Old Oct 3, 2007 | 10:48 PM
HoLLo's Avatar
Roll the key backwards so the radio is only on? does that make the ding?
Old Oct 3, 2007 | 11:17 PM
letsrun97z's Avatar
lol yeah me too greencamaro turn it all the way back then pull the key out a lil it turns off the ding
Old Oct 4, 2007 | 02:00 AM
chromeplated500's Avatar
grab your ***** and take a deep breath... lol... no but it wont ding if you leave your lights on... and that might save your *** sometime...
Old Oct 4, 2007 | 02:07 AM
TwoFast4Lv's Avatar
Just reach up under the dash on the driver side and unplug it
Old Oct 4, 2007 | 03:11 AM
Bones Z28's Avatar
it's annoying i admit, but i usually have the garage stereo system blasting so i don't here it to often.
