New LT1 Intake
Old Nov 13, 2007 | 02:29 PM
  #161
Vicious95Z28's Avatar
Originally Posted by Speed Density
This thread has been going on for a while, where is some evidence that there is a product?
Im curious..
Yup, I'm with Tony on this. Sorry to be a sceptic
Old Nov 13, 2007 | 02:33 PM
  #162
Originally Posted by thesoundandthefury
Here's some inspiration/food for thought:
http://www.youtube.com/watch?v=rsG4R4L-Gxk
This is a new intake that is very close to being released for retail sale. It's called the Barry Grant "Badman" inline carbureted intake. It's based off an old Ford designed manifold from the late 60's early 70's called the "Cross Boss" that became outlawed in Trans-Am racing so they abandoned production on it in favor of the 4-barrel configuration.
In the video, pay close attention to the manifold base, which Barry refers to as the "Aero Ram." It's this design that I think would be the most plausible and come the closest to being made into an LSx "folded hands" style manifold for the LT1.
Where the stock intake is compromised is the fact that GM had to incorporate an EGR tunnel that ran underneath the main plenum. If you eliminate the EGR tunnel as a design concern, you can utilize the dead space that it would normally take up in favor of situating the runners so that they would run across and through this area. This is essentially what the Badman Aero Ram base does:
Notice the nice straight shot from one side of the manifold to the other:
If you wanna break this down into simplistic terms, this manifold design is really the polar opposite to the LSx design, but essentially arrives at the same conclusion. The LSx manifold has a plenum that the runners wrap up, over, and around the top of. This Aero Ram intake would have a plenum up over the top and the runners would run down, under, and across it.
I think this Aero Ram manifold base, (or at least, the overall design), would make an excellent candidate to fabricate and weld on an upper plenum with an LT1 throttle body mating flange/linkage boss, and some bungs on the side.
I can't find the link I remember reading it in at the moment, but it was said somewhere that the runners in this base are 7". If someone got creative with how they fabbed up the upper plenum, they might be able to add an inch or so.
LSx= hands folded with fingers facing up
AeroRam= hands folded with fingers facing down
This I'm interested in
Old Nov 13, 2007 | 05:37 PM
  #163
MysticLT1's Avatar
interesting.... and very interested... make it happen
Old Nov 15, 2007 | 07:19 PM
  #164
r_trigg's Avatar
Default shucks...I think sheetmetal is just fine.
Old Nov 15, 2007 | 07:41 PM
  #165
buffman's Avatar
what's the pricing on one of those? ^^
Old Nov 15, 2007 | 07:49 PM
  #166
LS1 Eddie's Avatar
I say if something can be built, all it needs is results and a reasonable price. I'm very interested.
Old Nov 16, 2007 | 07:31 AM
  #167
LittleRedZ's Avatar
Originally Posted by TAEnvy
Guys It may actually be better to just convert to a single plane.
If there manifold costs 1K (Im just comparing it to something like a fast 90/90), How much would a Single plane run.
I think If you really want to make a good LT1 manifold, base it off the stocker. Its really not all that horrible for what most of us use or cars for.
**** It could even be cast and then cleaned up afterwards by hand to save some money. Itd also be nice to see it with a trap door or somehting to make porting easier, If I had the means to start it up thats how Id go, seems like itd be way easier and cheaper.
its funny you know i watch these guys jump all over this thread not even realizing nothing has been proved, if somone builds one dosent mean it will be better. Single plane is a proven performer and the cheapest solution period. So if you want an intake so bad buy a supervic +elbow+TB and take it over to machine shop to have it converted and stop waisting your time
Old Nov 16, 2007 | 09:13 AM
  #168
TwoFast4Lv's Avatar
We have looked at many cross ram style intakes like this. the biggest problem always comes down to where are you going to put the injectors. GM used a PITA setup on the Vortec to get around this. Not some thing that is easy to work on.
Old Nov 16, 2007 | 09:16 AM
  #169
LT1-DAN's Avatar
Old Nov 16, 2007 | 09:38 AM
  #170
SAPPER's Avatar
ALmost every has done away with the EGR anyway. So, EGR tunnels shouldn't be an issue or even in the design. But I can just imagine the amount of R&D involved. Due to runner length, angle, size and which TB to use: Single LS1 Style or the original dual blade LT1 style. I say stick to the LT1 style, the look better.
Old Nov 16, 2007 | 01:17 PM
  #171
Originally Posted by r_trigg
That's like aluminum SEX!
Old Nov 16, 2007 | 10:29 PM
  #172
chief455's Avatar
With a $1000/hr hooker
Old Nov 17, 2007 | 08:42 AM
  #173
LittleRedZ's Avatar
Old Nov 21, 2007 | 03:48 PM
  #174
thesoundandthefury's Avatar
If they're going to fabricate their own manifold, I think they can get around this problem but still end up with something that is relatively close. The Vortec intake is an automatic disadvantage for an EFI conversion because of the width of the plenum, but that's because GM chose to keep the runners straight.
Curve the runners in an "underhand" configuration to narrow the plenum down like on the LSx intakes, and I think the injector issue won't be a problem.
Old Nov 30, 2007 | 06:10 PM
  #175
LTBANDIT's Avatar
GGPC, any updates?
Old Nov 30, 2007 | 11:09 PM
  #176
95greenZ's Avatar
subscribing
Old Dec 1, 2007 | 08:54 AM
  #177
Blackbirdws6's Avatar
is it possible to cast a new manifold from a sheetmetal manifold? It won't be sheetmetal anymore but it should retain the same design in a different material correct?
-Brian
Old Dec 1, 2007 | 09:23 AM
  #178
speed_demon24's Avatar
-Brian
Sheetmetal intakes are 1 of a kind built specifically for one application so that won't be a very good idea.
Old Dec 1, 2007 | 10:18 AM
  #179
slick1851's Avatar
Thats fine but its not cheap, people want a reasonable bolton intake
Why is that so fucken hard? I dont really know!
Old Dec 1, 2007 | 11:36 AM
  #180
BlazerINtheWork's Avatar
never "waisted" time before
