Grounding Kit = 9HP?
thanks for the help (kinda)
Now, if you woulda come on here saying "I'm gonna replace my 'big 3' so my lights will be brighter", then I wouldnt have anything to pick on you about.
But you didnt. You came on here and stated that its "dyno proven" that changing out your "big 3" will increase HP. Thats just silly.
And as far as my e-***** goes, I'm not the one that came off sounding like I was trying to school someone. You were.
I'm not an IT guy. I'm a car guy. I run a dyno everyday. I solve electrical problems on cars, everyday. Does that make my e-***** bigger? Maybe, if you have e-***** envy.
Let me explain it this way, see if you guys may get off the bandwagon long enough to make an intelligent conversation out of this instead of chalking it up as the next tornado.
Ever heard of or seen someone use an aftermarket wiring kit for a fuel pump? These kits, which can also be just rewired yourself, increase the gauge of wire for the power and ground. Why do that? Surely the awesome GM electrical system can feed the pump enough juice right? Wrong. When you install one of these kits, the headroom of fuel pressure rises significantly. Still think the Big 3 is a dumb idea? What about saying that every little bit helps? Like the airfoil mod. What a joke right? Does very little. Hey, but it does something right? Why not toss it on?
regardless of a performance increase or not, but a lower resistance in your electrical system will probably make your electrical components last longer, wouldn't it?
hmm... less resistance in the grounding system of your car could possibly make an opti last longer???? it's a stupid idea, but damn, if it meant prolonging the enevitable opti shitting out on me, it's worth any amount of money!
