brake peddal is hard as hell to push
Old Oct 19, 2007 | 07:47 PM
That_guy's Avatar
Default brake peddal is hard as hell to push
i just seafoamed my car and i was going to go drive it as i was going to put it in park i noticed the brake peddal was hard as hell to push. so that would mean that some brake fluid is needed right if so which would be the best one to get.
Old Oct 19, 2007 | 07:49 PM
kinglt-1's Avatar
Look at your master cylinder to see if its low!
Old Oct 19, 2007 | 07:51 PM
Revelation Z28's Avatar
check if you left the brake booster hose off.
Old Oct 19, 2007 | 07:56 PM
That_guy's Avatar
o yea lol ok ok and i am low on fluid . and the hose is on
Old Oct 19, 2007 | 08:05 PM
That_guy's Avatar
ok its not the brake booster. and i was low on the fluid so which fluid should i get
Old Oct 19, 2007 | 08:08 PM
Formula350's Avatar
Dot 3 heh. I believe the Dot4/5 can work, as in it's backwards compatible...
If it's still hard after that, then it's just probably one of two things, a dead master cylinder or a dead brake booster (the big cylindrical thing )
Old Oct 19, 2007 | 08:11 PM
speed_demon24's Avatar
Being low on fluid wouldn't make the pedal hard to push.
Old Oct 19, 2007 | 08:13 PM
That_guy's Avatar
goin to buy a can right now. i hope its the brake fluid
Old Oct 19, 2007 | 08:16 PM
Formula350's Avatar
Speed is right though. I can't remember if air in the line will do that though. Which low fluid could be the cause of.
Old Oct 19, 2007 | 08:55 PM
That_guy's Avatar
ok got some fluid and i put it in and its still doing it. how do i bleed the brake system
Old Oct 19, 2007 | 09:00 PM
Enforcerws6's Avatar
If the brakes need bled you would have a soft pedal. I doubt it was low enough to need that done. You either have a bad booster or more then likely you lost vacuum to the booster some how or your car is idling very low and not building vacuum
Old Oct 19, 2007 | 09:13 PM
That_guy's Avatar
hahaha ok well the ******* brake booster sucks then. i guess it is that. so how much for another one.
jasonp31's Avatar
Seafoam is really good about blowing vac lines off. Check all your lines. Maybe the brake booster hose is on, but maybe you blew another key line off, and now your vacuum is low. Do you have a gauge to check vacuum? Check every single vac line you can find, make sure none of the lines are split. Also, a swivel adaptor is usually present on the brake booster, where the vac hose attaches. Is it in all the way?
Is your master cylinder leaking? Check underneath it, along the lines, etc.
Old Oct 19, 2007 | 11:16 PM
jester1614's Avatar
if it does come down to it i have a brake cylinder and a booster of of a 95 formy that are up for sale
pm me if interested
