CC306 cam only guys ???
Old Oct 20, 2007 | 11:49 PM
Camz450's Avatar
Default CC306 cam only guys ???
I am installing the cc306 in my auto with a 3000 stall and 373 gear. I was wondering if anyone drove their car with this cam before it was tuned for it. I will be driving it from the shop to my home which is approx an hour drive, will have to wait to see when i can get dyno time or mail order tune, any hepl appreciated!!!
Old Oct 21, 2007 | 12:05 AM
mean_greenZ's Avatar
oh yea lots of people drive there cars before it is tuned. a friend of mine just got his 383 build done and it hasnt been tuned yet and hes been driving it for like 2 weeks
Old Oct 21, 2007 | 07:16 AM
jakesz28's Avatar
Mine would not idle with that cam before a tune. There was no way I would have been able to drive it around. You will need more timing down low, higher idle setting. But every car is different.
Old Oct 21, 2007 | 10:37 AM
GreenBlood's Avatar
driving should be ok for a while...i plan to go big cam soon...my insurance covers towing though in case the bitch won't go, lol...
Old Oct 21, 2007 | 12:21 PM
Matts94Z28's Avatar
I wouldn't do it.
Old Oct 21, 2007 | 01:37 PM
Camz450's Avatar
Yeah i think I am going to do the exchange program with pcmforless, I think its only $175 after you return your pcm, or maybe the trifecta hand held thats out there.
Old Oct 24, 2007 | 10:14 AM
roadhog_113's Avatar
don't go nuts on it just break it in.
Old Oct 24, 2007 | 10:24 AM
Revelation Z28's Avatar
+1 for driving easy untuned. let the bearing journals wear in until the tune. then use the cam the way its meant after!
Old Oct 24, 2007 | 10:57 AM
The93z's Avatar
I wouldnt even do the 306 without getting some supporting mods with your heads, it should actually decrease performence. But you will need a tune either way.
Old Oct 24, 2007 | 02:03 PM
BizZzatch350's Avatar
Moderator
Not really, tuned right it'll make some power, theres been a couple good running cam only CC306 cars, would that be the best cam for a cam only set up, probably not, but it wont run slower than a bolt on car thats for sure.
Old Oct 24, 2007 | 02:52 PM
revelation that is one awsome convicted picture lmao!
Old Oct 24, 2007 | 03:01 PM
GaJoe's Avatar
you won't be getting the full potential of the cam....you'll have to stop short of the peak power band or you'll end up w/ some spent bearings at the least if you're lucky....I would break it in, tune it, then drive it...you have a msd...if it's a 6al run a limiter...
Old Oct 24, 2007 | 03:56 PM
Camz450's Avatar
I know its not the best for cam only and I know I should get the heads ported. This car has 95,000 miles on it and i just wanted the crazy lope it offers along with how it performs with the juice. I studied the decision and happened to find a good deal. this is only short term until i build a stroker LT1 new from top to bottom. Thanks for all the replys !!!
Old Oct 24, 2007 | 04:11 PM
GaJoe's Avatar
in that case, I like the way you're thinkin! haha
Old Oct 24, 2007 | 05:55 PM
Bersaglieri's Avatar
Wow, lots of CC306 haters huh?
I guess the folks trapping 115 cam only full weight with the CC306 are decreasing their performance over just bolt on's? Most have no problems cracking of very low 12's with a decent setup.
I've seen this crappy cam run some damn good times, even into the 9's.
Let's try not to drink to much kool-aid, ok?
-Dustin-
Old Oct 24, 2007 | 06:01 PM
Matts94Z28's Avatar
LOL @ decreasing performance.
Old Oct 24, 2007 | 06:11 PM
Decreasing performance cam swap F.T.W..!
-Dustin-
Old Oct 24, 2007 | 08:07 PM
InnocentZ28's Avatar
cam only 306 in mine deffinatly pulls a lot harder than stock.
Old Oct 24, 2007 | 10:39 PM
Matts94Z28's Avatar
lol i have seen 7.60's-7.90's out of cam only 306 cars with gears, stall, LT's and DR's.
Old Oct 25, 2007 | 12:38 AM
on youtube theres a CC306 cam only full bolton guy putting 360 to the wheels.
