feels like throttle sticking...
Old Oct 30, 2007 | 04:47 PM
Pony_Killer's Avatar
Default feels like throttle sticking...
Finally got to pull the car out of the garage today and take it for a spin after installing the headers making sure everything was ok before I have the duals put on....well I took it down the road holy crap it was loud but everything seemed ok until I let off the gas....its hard to explan but its like I'm pushing in the gas pedal then letting off over and over with a jerking feeling until I put my foot on the gas and it calms down..what could be making it do this?
Old Oct 30, 2007 | 04:52 PM
HoLLo's Avatar
Maybe lube up the throttle cable body?
Old Oct 30, 2007 | 05:11 PM
Ya I tryed that earlier but no luck...I pulled my TB Plate off and noticed a lot of oil in there..should that be there?
Old Oct 30, 2007 | 05:14 PM
ThoR294's Avatar
uh no. that means something is wrong with your PCV system
Old Oct 30, 2007 | 06:02 PM
Ya I think I know y its getting oil..my pcv is just a hollow elbow looking thing...once I get a new pcv what do u think is the best way to get the oil out maybe remove the lid and spray it down with TB cleaner or do u think its going to need to be removed?
Old Oct 30, 2007 | 07:20 PM
ThoR294's Avatar
depends on how bad it is. i would take the throttle body off and check
Old Oct 31, 2007 | 03:29 AM
Ralls's Avatar
Have you done a throttle body bypass? And what is the temperature outside?
Old Oct 31, 2007 | 05:07 AM
ya somebody did the bypass before I got the car,,,and Its still decent around here.. 60's-70's when I first put my TB cover on a few months ago there was some oil traces but not much and I was able to clean it out with a rag but nothing like now ..
Old Oct 31, 2007 | 02:52 PM
Ralls's Avatar
Yeh thats not cold enough for the throttle blades to stick. Your always going to have some oil under the throttle plate, but not a lot. If you have puddle and it's dripping in the intake, I could see how the engine might "cough." See if the PCV valve is still working. Put your finger on the end with the car on and listen for a click.
Old Oct 31, 2007 | 06:11 PM
SLawson86's Avatar
clean the throttle blades and bore. get some carb cleaner or brake clean and spray it out really good. oil residue causes them to stick quite a bit
