top speed?
Old Feb 8, 2008 | 12:06 PM
  #101
30thanniversaryz's Avatar
Originally Posted by sweet-94z28
I tried it one time and one time only. I hit about 152 and she was still going at 5K. I would say 160 is tops for an A4
Weird...I had my 3.23 A4 at 152ish and was only doin between 4000 and 4500.
Old Feb 8, 2008 | 12:34 PM
  #102
LT1MAN's Avatar
Originally Posted by glocklimited9
We build my cousins 94 trans am 6m with 4.10s, and would bury the speedo in a heartbeat and still pull like mad.
thats because the speedometer is off.
Old Feb 8, 2008 | 12:40 PM
  #103
NXPRSS's Avatar
I have had my LT1 to 140 many times... but the fastest i have gone in it was 145 and i just ran out of room.... definately had alot more in it.... and my car was basically stock when i did the 145 run.... but i agree 0-100 is alot better, banging through the gears as fast as you can....
Old Feb 8, 2008 | 05:39 PM
  #104
the_merv's Avatar
Veteran: Air Force
Originally Posted by camar0corey
You are right around the weight of a new z06 and have more power to the wheels than one, so why not? At least in theory, did you get that dyno'd yet?
Not yet..
Old Feb 8, 2008 | 06:03 PM
  #105
daniel6718's Avatar
around the weight of a z06? as in 150 pounds more than them...
and a smaller motor with not as good heads or intake....and an auto not a 6 speed...and worse aerodynamics...along with much worse weight distribution
Old Feb 8, 2008 | 06:21 PM
  #106
SPDEMON's Avatar
I have had my car (the trans am) up to 160 in 5th gear at about 5800 rpm and called it quits.
I shift at 6400 so I still had 600 rpm left in 5th and another whole gear to boot. The car was still pulling....hard.
I have 3.73's and if I was to top out 5th....were talking 180mph at 6400 rpm. There is no doubt in my mind that I could top out 5th gear. Any f-body with 450hp+ should be able to.
I think the trans am is more aerodynamic than the camaro, but let me tell you, I have the formula hatch (no spoiler) and at 160 it felt like I was going to take flight at any time.
