good job Justin, Your moving right along. Are you tunning with Hp tuners and are you going to switch to SD tune now. I would have thought you already went to that. When does your meth kick in?
HP tunes does not have tuning software for the LT1. I dont think he is running meth.
man i trap around 135 and i have fun on the street...with turbo its perfect you can leave soft and as it comes into boost your already rolling and suspension is loaded...perfect...ive seen turbo cars 3 feet up in the street
Matt, I'm using Tunercat to tune it, on the lt1's the map sensor can't see any boost at all so I'm tuning completely off the maf, and when it maxes out I add fuel via the Power enrichment vs rpm. I'm not running any meth at all right now.
I actually hooked A LOT harder on my nitrous, although my current tires only have a 8.7" tread width.
