LT1 vs LS1
And I'm not even from Wisconson. But I am from Chicago where we are taught at birth to hate the cheeseheads up in Green Bay.
But I have to admit that Brett Farve is impressing me as much as 11.1 @ 119 did. He should be done and washed up but here he is lighting it up and giving Dallas a run for thier money in the NFC.
Ok enough football. Now back to the LS1/LT1 thing
I gave you one showing the LT1 cam only record is 11.1 @ 119. Show me something concrete and I'll believe you. Until then..........
The record stands at 11.1 @ 119.
..... doesn't change the fact that the LT1 record currently stands at 11.1 and the LS1 record is 10.2.
60'...1.355
330...4.188
1/8...6.614
MPH...101.03
1000...8.720
1/4...10.510
MPH...122.36
LS1's have been in the 9's stock headed. Just because they do not make a forum account does not mean they do not exist
Since you love forums so much though, here are a few quick picks from a minute or two of searching - pay close attention to some of the dates - this is no new discovery!
What is a Stock Eliminator LT1?...
https://ls1tech.com/forums/showpost....7&postcount=27
10.7's in a HEAVY(3400+) "stocker" LT1 firebird? Sure
http://www.highperformancepontiac.co...ips/index.html
...and a look into LT1's in Stock Eliminator Racing. Surely CHP would not lie about an LT1's performance?
http://www.chevyhiperformance.com/te...nfo/index.html
I can go on, but dont want to waste my time. Mid 10's with unported heads is COMMON for LT1 cars under strict NHRA stock class rules - stock TB, unported heads, no trans brake, stock lift cam, etc.
With more lenient rules they would all be bottom 10's/high 9's cam only.
Go to a regional points event and see for yourself.
FOr the record, Tom Bishop in an A/FI 97 firebird holds the record in that class with a 10.38
He aint on no message board, he is a professional racer.
PUCK, you forgot to let him in on the fact that most cars in EFI run a 30x9 tire...only 9 inches wide and tote the front wheels
David
Guess what? THEY HAVE. Thank you for proving my point on your close minded view of "Message Board Racing"
http://www.teamjegs.com/thecars/superstock.asp
Specifically this statement in the article:
Strict rules apply to Super Stock engines, which must use factory matching blocks, cylinder heads, and carburetors. Engine modifications are limited to the addition of aftermarket intake manifolds, exhaust headers, and valve train components. Mildly ported cylinder heads are also permitted.
Mildly ported heads are permitted? Then I did some research on Gizmo and found this:
Quite frankly there are a number of trick pieces you can use in a stock eliminator cylinder head and still remain legal from a racing perspective.
That was a quote from this link that you provided me:
Don't get me wrong. I found the links very imformative and most impressive. But there is a reason the searches on cam only record didn't show guys like Gizmo. Because they are not 100% GM built untouched LT1 heads.
Bud Rowe 1995 Z28 B/FIA 10.471 -1.229 under index
Russell Fox 1997 Z28 B/FIA 10.583 -1.117 under index
So the cam only record still remains 11.1 @ 119 unless someone can issue me a link that describes a LT1 car going faster under the following peramiters:
GM built LT1 motor (no LT4's, 383's, ect)
GM issued and unported/untouched LT1 heads
No power adders
As far as I see the times to beat are still 11.1 for LT1's and 10.2 for LS1's.
A valvejob to him is not stock, which is all an LT1 stocker is allowed......he's a dumb ***, leave it be.
David
If it was so easy to run 10's cam only then why isn't Frank95Z deep in the 10's? Why has no one over all these years done it? Records are always a milestone that attact people. Surely someone has attempted to break that record before. I know for a fact someone (probably more then one) is trying to break Shons 11.8 bolt on record as we speak. They may or may not do it but someone is always thinking of ways to be a record holder.
My position has remained unchanged. If you modify the heads to gain an edge then they are no longer stock. Under the conditions of this debate the record is still 11.1 @ 119.
Get one of these stock or super stock guys to strap on a set of untouched factory LT1 heads onto a factory built LT1 motor with any cam they like and then get back to me with the results. If they make a 10.xx pass then I'll give him props and we can alter the discussion at that time.
Until then the LT1 and LS1 records remain nearly a second apart with the LS1 in the lead. And considering the better flowing head design of the LS1 it's as it should be.
But with all this side tracking of NHRA stock and super stock did anything really change? Is the LS1 still not faster stock vs stock? Is the LS1 still not faster bolt on for bolt on? Is the worlds fastet LS1 still not faster then the worlds fastest LT1?
Is the LS1 still not a better motor design created by GM to be an upgrade to the LT1?
I don't know about you but I gotta say yes to all of the above.
Its all about cash for power.
I know guys with LT1 cars that will dust your 12.3 LS1 and they have far less money into thier ride.
Thats what its all about.
My former classmate paid 11K for his 70K mile LS1 a couple years ago.
I paid 4400 for my 82K LT1.
Geee, do ya think I can make my LT1 faster with the extra 6K? :
