LT1 vs LS1
I use to own an LT1 and think like you too b/c I had never owned an LS1 and always felt like an underdog. LT1 is a great motor, but be realistic on results. You have to do a crazy heads/cam to get 480 out of a LS1.
. Ported stock castings are far superior to most out of the box aftermarket.Thats rediculous, I'll be damned if a bolt-on LS1 comes within CAR LENGTHS of my daily driven LT1.
Horrible choices and lack of information is what keeps so much of the LT1 crowd slow. LS1s are just more tolerant to ignorance
BTW since when did it turn into a dyno e-tourny. (Oh and check 97blkz's user title rofl)
There are countless members on here and people you will never see pushing 400-500rwhp with stroked H/C LT1's.
Many LS1's can't get out of 13's with bolt on's.
Stop crying you sound like a little bitch.
I use the sig to reel suckers in, it worked on this one.
Would have been real simple to just look at the MPH and seen that it doesnt add up
Your sig time was 10.3 IIRC? I remember it was low 10s but the number currently is escaping me.
if you want to get LT1 f-body ( camaro or TA) than you can get more power by getting the GM performance parts 215cc 18* degree heads p# 24502580 and convert them to LT1 style that way i guess you will make power as much or close to LS1 if not even more.
actauly for car look or sound specially with Hooker Long Tube headers i certainly like the LT1 more and i prefer the LT1 camaro look over a LS1 camaro. i owned before a 94 LT1 A4 camaro with heads/cam mods and Hooker long tubes and i own now my 2000 LS1 M6 camaro mods in the signature and difintly the look and sound of the LT1 camaro is better than the LS1 specailly the sound but in terms of power difinitly the LS1 camaro is more powerful.
If it is then please link me anything that shows a dyno chart of someone making 480 rwhp on a stock cubed LT1 with just heads/cam and bolt ons.
Some M6's stock have hit 12.9 and you know it. The LS1 bolt on record is in the 10's and you know it. And getting high 11's or low 12's with bolt ons alone has been done many, many times. All it takes is the right bolt ons (no tornados or performance chips), the right tires (no street tires) and some decent racing conditions (no Denver type elevations).
Isn't that a bit hypocritical?
But I seriously doubt that you're damned because a few bolt on LS1s could not only run within a few cars of you but actually be the one in the lead
Mid 11's may not be any record setting run - fairly average times for a thought out build if you ask me - but that is N/A on DR's in my full weight daily driver. I can positively be low low 11's or high 10s on motor if I did not have to worry at all about drivability. 4.10s instead of 3.23s, full slicks, much more aggressive cam, larger stall, etc would get it done. You make it seem as if the heads/cam was needed for me to run 11s. The fact of the matter is, it was needed to run streetable, reliable times in the car I choose drive at least 4 days a week.
There is no argument that the LS1 is a newer, more powerful superior engine...but it is not nearly the thrasing that you guys make it out to be.
If it was so easy, why are you still running 12.3?
I only ran a couple tenths slower then that in my bolt on LT1
2). Send me a link to cam only LT1's running 10's. If the worlds quickest bolt on LT1 is 11.8 then I would love to see what cam drops .8 or more from that.
3). The quickest bolt on LT1 is 11.8 and the quickest bolt on LS1 is 10.8. The point you failed to see is that with less mods (stock heads or bolt ons) LS1s can run a full second faster then the car you claimed:
He said nothing about transmissions or power. Just that many can't get out of the 13's. So I sarcastically showed that my car with less then full bolt ons shattered into the lower 12's.
Like I said in a previous post, I don't have all the bolt ons. If I was so inclined I could get a LS6 intake, 3.73 gears, underdrive pulley, upgrade my stall to a Yank PT4400, EWP and get another dyno tune. That has 11's written all over it. But that's not going to happen because I'm going a different route.
I have a set of ETP LS7 heads, LS7 intake, custom cam, underdrive pulley and a lot of other stuff that's going on a 408 shortblock. I was going to go 416 but I like the idea of the iron block for spray since I want to run an occasional 200 shot.
But like you, I want a hint of streetable. So the cam and stall won't be ***** to the wall. I just want a reliable mid to low 10 second car that can see 9's on spray.
As to the times, there are way more 11 second bolt on LT1s then shon - the world is a bigger place then LS1tech.com. Even 10 second cam only cars are possible, and often done in racing classes that limit the field to factory heads. Not saying they are as streetable - but in a track only car, who cares? I'm sure GIZMO can tell you a lot more then about that then I can though.
It was already stated that the LS1s have the edge(as they should have) but that gap is not as large as some make it out to be - it depends on the build. True, my "bolt-on" time had quite a few more mods then you, but was only 4 tenths slower. Most definetly within "driver error" range if the cars were manuals.
If I was so inclined to convert some other heads to LTX(SB2.2?) the biggest benefit of the LS1 would be out the window. It all depends on the build and choice of parts
You can make an argument that someone who picks the best parts for a LT1 heads/cam setup can run right with someone who picks shall we say bang for the buck parts for a LS1 heads/cam setup.
But when all things are equal, including the quality of parts used, the LS1 still maintains its advantage.
We're not arguing, we're debating. There is a difference you know. For one we're not using a lot of profanity and two we're not slinging around personal insults.
We all agree the LS1 is superior, and that mod for mod they are quicker. It is just in the "details" where our opinions differ.Seems tame to me compared to most LT1 vs LS1 threads!
For the "proof" you ask for, just search for stock eliminator LT1s. Don't expect them to tell their "secrets", but many are 10s with untouched heads cam only. With the right setup, 11's cam only is not as hard as you would think. Some may call it easy
Throwing an off the shelf cam and some pacesetter longtubes and expecting miracles is what usually happens, which leaves people with a sour taste in their mouth for LT1s.Cam only Lt1s do not usually run as quick as cam only LS1s for the obvious reason - the head flow.
